Upgrade failed
Told my Eisy to upgrade but now I can't connect to it. UD Mobile is saying it is offline. I tried unplugging power and plugging back in to reboot but no luck. What else can I do?
Yeah IoX launcher says not found so can't get to the admin console. I unplugged it and let it sit for a while but no luck. I should have not tried to upgrade since it was working.
Edited by GregE
Two useful things to know as you open a ticket:
  • Can you see it in your router'sdevice table? If so, can you ping it?
  • Be prepared to hook up a keyboard and a hdmi screen if asked to do so.
After clearing your Cache, try to connect to it directly via http://<your eisy ip address>:8080/admin.jnlp
This will download an AC shortcut called Admin.jnlp. Clicking on that should take you directly to a sign in screen versus the AC launcher. This will eliminate quite a few of the possible "in-between" issues.
However, it sounds like your Eisy may be locked up .
Yeah I can ping it and they did ask me to do that but I have neither at home so will have to bring one once I am back at work.
