Cannot add favorite
I am running UDM 1.4.11 (260) and noticed that 1 of 2 Eisy sites lost all of the favorites. Tried to use backup but app froze. Had to delete app, then re-download, then could restore using backup. However, some favorites were not there, so I tired to add back. Attached is what happens when I try to add a door lock. After adding the node, "Display Status" appears, but when this required area is opened, there is nothing to select. End result is that I cannot add the door lock. Running iOS 26.2, IOX 6.0.4
Solved by DennisC
Try rebooting eisy first. Also, be sure to synchronize UD Mobile, then try adding the favorite back.
