January 15Jan 15 I have a EcoNET Bulldog water valve installed. This is a z-wave device that turns off my main water valve. It used to work with the ISY but the eisy cannot find it. I've turned off the S2 option but it still cannot find it. The company is saying that the issue is that the eisy cannot link to the EVC200 control module.Anyone have any experience like this? The "solution" is a new one that is matter over wifi for $100.
January 15Jan 15 What controller and what controller firmware are you runningWhat is the model number of the valveHow far is the controller from the valveHow many non-battery operated zwave devices do you have in your system
January 16Jan 16 6 hours ago, raydoc said:The company is saying that the issue is that the eisy cannot link to the EVC200 control module.This is the kind of thing you should open a support ticket with UD on. Chris would be able to determine if it can be linked to UD device, or maybe even make a small tweak to make it so.
January 16Jan 16 The EVC200 is Zwave certified so it should work assuming you have a viable zwave network
January 16Jan 16 14 hours ago, tlightne said:Did you exclude it before trying to include it on the Eisy Zwave??Yes, you should definitely try that first.
January 16Jan 16 @raydoc , looks like you previously had an ISY994. That being the case, the EISY should be able to find your EVC200 ASSUMING it's in range.Unfortunately the valve appears to be "z-wave plus" or z-wave 500 series. Not the best for range and very difficult if you don't have a robust mesh. Newer 700/800 series devices are greatly improved.Since you obviously can't move your valve closer to the EISY, try moving the EISY close to the valve as shown in the users manual below. You should absolutely try excluding the valve 1st since previous excludes will not have worked with the EISY out of range.
