February 12Feb 12 I have a Venstar T7800 with the wifi adapter. The thermostat is logged into Venstar Skyport and that works. I enabled Local API.I installed the PG3x node. I clicked "discover". It gave me a message that it failed to find a thermostat. I manually entered an incorrect IP address and it gave the same message (this was an accident, transposed two digits). I corrected that mistake and then hit discover and it does nothing. No messages, no nodes, it is like I didn't hit the discover button. I tried deleting the node and installing again in a different slot. Same results. I tried changing back to an incorrect IP and it gives the message that nothing is there again. The discover button is activating, it changes from almost black to black when I click it. It would seem that the node server is seeing something there but getting in some failure loop or something?Next step?Thanks.EDIT: Also I have put the latest firmware on the thermostat.EDIT2: I put the url (http://192.168.3.127) into a web browser and got this response. {"api_ver":5,"type":"residential"}If put http://192.168.3.127/query/status it just spins and spins.I'm going to try power cycling the thermostat later today when I am physically there. I'm working through a local pc via vpn/remote desktop.@Goose66here is some of the logAutoScroll 2026-02-12 10:01:26.107 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message discover2026-02-12 10:01:26.108 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING discover2026-02-12 10:01:26.109 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS discover message {} from Polyglot2026-02-12 10:01:26.110 Thread-54 (_discover_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving2026-02-12 10:01:26.111 Thread-54 (_discover_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.2026-02-12 10:01:26.111 Thread-54 (_discover_handler) udi_interface DEBUG venstarapi:getThermostatInfo: in getThermostatInfo()...2026-02-12 10:01:26.119 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}2026-02-12 10:01:26.167 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom2026-02-12 10:01:26.168 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom2026-02-12 10:01:26.169 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot2026-02-12 10:01:26.169 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot2026-02-12 10:01:26.170 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}2026-02-12 10:01:26.208 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices2026-02-12 10:01:26.418 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-02-12 10:01:26.419 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-02-12 10:01:26.419 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-02-12 10:01:26.420 Thread-55 (_poll_handler) udi_interface INFO venstarns:shortPoll: Updating node states in shortPoll()...2026-02-12 10:01:26.528 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Exception in thread2026-02-12 10:01:26.528 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Thread-54 (_discover_handler)2026-02-12 10:01:26.529 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: :2026-02-12 10:01:26.529 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last):2026-02-12 10:01:26.529 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/site-packages/requests/models.py", line 976, in json2026-02-12 10:01:26.532 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: return complexjson.loads(self.text, **kwargs)2026-02-12 10:01:26.534 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.534 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.535 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.535 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.535 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.536 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.536 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.537 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.537 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.538 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.538 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.539 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.539 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.540 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.540 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.540 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.541 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.541 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.542 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.542 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.543 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.543 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.543 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.544 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.544 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.544 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.545 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.545 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.546 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.546 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.547 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.547 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.548 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.548 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.548 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.549 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.549 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.550 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.550 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/json/__init__.py", line 346, in loads2026-02-12 10:01:26.553 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: return defaultdecoder.decode(s)2026-02-12 10:01:26.554 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.554 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.555 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.555 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.556 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.556 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.557 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.557 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.557 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.558 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.558 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.559 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.559 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.560 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.560 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.561 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.561 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.561 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.562 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.562 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.563 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.563 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.563 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.564 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.564 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.565 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.565 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/json/decoder.py", line 337, in decode2026-02-12 10:01:26.567 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: obj, end = self.raw_decode(s, idx=_w(s, 0).end())2026-02-12 10:01:26.568 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.569 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.569 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.570 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.570 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.570 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.571 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.571 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.572 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.572 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.572 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.573 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.573 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.573 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.574 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.574 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.575 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.575 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.575 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.576 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.576 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.577 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.577 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.577 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.578 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.578 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.579 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.579 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.579 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.580 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.580 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.581 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.581 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.581 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.582 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.582 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.582 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.583 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.583 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/json/decoder.py", line 355, in raw_decode2026-02-12 10:01:26.585 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: raise JSONDecodeError("Expecting value", s, err.value) from None2026-02-12 10:01:26.586 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: json.decoder2026-02-12 10:01:26.587 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: .2026-02-12 10:01:26.588 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: JSONDecodeError2026-02-12 10:01:26.588 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: :2026-02-12 10:01:26.589 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Expecting value: line 1 column 1 (char 0)2026-02-12 10:01:26.589 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: During handling of the above exception, another exception occurred:2026-02-12 10:01:26.590 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Traceback (most recent call last):2026-02-12 10:01:26.590 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 1045, in bootstrapinner2026-02-12 10:01:26.594 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: self.run()2026-02-12 10:01:26.595 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/threading.py", line 982, in run2026-02-12 10:01:26.598 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)2026-02-12 10:01:26.600 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593970_8/venstarns/nslib.py", line 87, in discoverhandler2026-02-12 10:01:26.602 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: self.discover()2026-02-12 10:01:26.603 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593970_8/venstarns/venstarns.py", line 143, in discover2026-02-12 10:01:26.604 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: thermoInfo = api.getThermostatInfo(hostName, LOGGER)2026-02-12 10:01:26.605 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.606 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.607 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.607 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.608 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.608 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.608 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.609 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.609 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.610 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.610 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.611 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.611 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.612 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.612 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.613 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.613 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.614 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.614 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.615 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.615 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.616 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.616 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.617 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.617 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.618 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.618 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.618 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.619 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.619 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.620 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.620 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.621 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.621 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.622 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.622 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.622 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.623 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.623 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.624 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593970_8/venstarns/venstarapi.py", line 385, in getThermostatInfo2026-02-12 10:01:26.625 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: thermostatInfo.update(response.json())2026-02-12 10:01:26.626 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.627 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.627 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.628 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.628 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.629 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.629 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.630 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.630 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.631 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.631 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.631 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.632 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.632 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.632 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: ^2026-02-12 10:01:26.633 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.11/site-packages/requests/models.py", line 980, in json2026-02-12 10:01:26.636 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)2026-02-12 10:01:26.637 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: requests.exceptions2026-02-12 10:01:26.638 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: .2026-02-12 10:01:26.638 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: JSONDecodeError2026-02-12 10:01:26.639 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: :2026-02-12 10:01:26.639 Thread-54 (_discover_handler) udi_interface ERROR udi_interface:write: Expecting value: line 1 column 1 (char 0)2026-02-12 10:01:46.389 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-02-12 10:01:46.390 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-02-12 10:01:46.390 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-02-12 10:01:46.392 Thread-56 (_poll_handler) udi_interface INFO venstarns:shortPoll: Updating node states in shortPoll()...2026-02-12 10:02:06.406 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-02-12 10:02:06.407 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-02-12 10:02:06.408 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-02-12 10:02:06.409 Thread-57 (_poll_handler) udi_interface INFO venstarns:shortPoll: Updating node states in shortPoll()...2026-02-12 10:02:10.370 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop2026-02-12 10:02:10.371 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop2026-02-12 10:02:10.372 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot2026-02-12 10:02:10.372 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.2026-02-12 10:02:10.374 Thread-58 (_stop_handler) udi_interface DEBUG venstarns:stop: In node server stop()...2026-02-12 10:02:10.375 Thread-58 (_stop_handler) udi_interface.interface INFO interface:stop: Disconnecting from MQTT... localhost:88832026-02-12 10:02:10.379 Thread-58 (_stop_handler) udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Normal disconnection. Sent by server: False. Retry in 10 seconds.2026-02-12 10:02:20.505 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=302026-02-12 10:02:20.506 MainThread udi_interface INFO init:<module>: UDI interface initializing2026-02-12 10:02:20.506 MainThread udi_interface INFO init:<module>: User=None2026-02-12 10:02:20.507 MainThread udi_interface INFO init:<module>: Home=/var/polyglot/pg3/ns/000db9593970_82026-02-12 10:02:20.508 MainThread udi_interface INFO init:<module>: Node Server Path=/var/polyglot/pg3/ns/000db9593970_82026-02-12 10:02:20.508 MainThread udi_interface INFO init:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTk6Mzk6NzAiLCJwcm9maWxlTnVtIjo4LCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJsMElGVS1DSmdNUDBvTmt2IiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMTEiLCJpc3lWZXJzaW9uIjoiNi4wLjQiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ==2026-02-12 10:02:20.509 MainThread udi_interface INFO init:<module>: Loading interface module2026-02-12 10:02:20.778 MainThread udi_interface INFO interface:<module>: Loading MQTT module2026-02-12 10:02:23.590 MainThread udi_interface INFO interface:<module>: MQTT module loaded2026-02-12 10:02:24.891 MainThread udi_interface INFO init:<module>: Loading udi_interface module2026-02-12 10:02:24.895 MainThread udi_interface INFO init:<module>: Loading node module2026-02-12 10:02:24.896 MainThread udi_interface INFO init:<module>: Loading custom module2026-02-12 10:02:24.896 MainThread udi_interface INFO init:<module>: Loading isy module2026-02-12 10:02:24.897 MainThread udi_interface INFO init:<module>: Loading OAuth module2026-02-12 10:02:24.900 MainThread udi_interface INFO init:<module>: UDI interface initialized2026-02-12 10:02:24.901 MainThread udi_interface INFO init:<module>: UDI Python Interface for Polyglot version 3 3.4.5 Starting...2026-02-12 10:02:24.923 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.4.11 [ISY: 6.0.4, Slot: 8]2026-02-12 10:02:24.924 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.3.82', 'netmask': '255.255.255.0', 'broadcast': '192.168.3.255'}2026-02-12 10:02:24.927 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:88832026-02-12 10:02:24.929 MainThread udi_interface INFO main:<module>: Starting VenstarCT node server...2026-02-12 10:02:24.931 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 000db9593970_8.cert key: 000db9593970_8.key ca: /usr/local/etc/ssl/certs/ud.ca.cert2026-02-12 10:02:24.966 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.2026-02-12 10:02:24.995 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.2026-02-12 10:02:25.091 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success2026-02-12 10:02:25.093 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:59:39:70_8 - MID: 2 Result: 02026-02-12 10:02:25.142 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']2026-02-12 10:02:25.260 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll2026-02-12 10:02:25.261 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll2026-02-12 10:02:25.262 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '5280b596-377f-4116-b330-a854973396f8', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customparams', 'value': '{"hostname":"192.168.3.127"}', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.265 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo2026-02-12 10:02:25.266 Thread-3 (_parameters_handler) udi_interface.custom DEBUG custom:load: CUSTOM: load {'hostname': '192.168.3.127'}2026-02-12 10:02:25.267 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '4b876651-db51-462a-a395-5cfe8f28e21d', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customparamsdoc', 'value': '<h2>VenstarCT NodeServer Configuration</h2>\n\n<h4>Advanced Configuration:</h4>\n\n<ul>\n<li>key: shortPoll, value: polling interval for thermostat states on the local network in seconds (default 15)</li>\n<li>key: longPoll, value: polling interval for alerts, sensor states, and runtimes in seconds (default 150)</li>\n</ul>\n\n<h4>Custom Configuration Parameters:</h4>\n\n<ul>\n<li>key: hostname, value: hostname(s) or IP address(es) for thermostat(s), seperated by semicolons, to bypass SSDP discovery (optional)</li>\n</ul>\n', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.269 Thread-3 (_parameters_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking hostname / 192.168.3.1272026-02-12 10:02:25.269 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom2026-02-12 10:02:25.270 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '354710a9-207c-4206-b98c-9bd1880bb47b', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customtypeddata', 'value': '{}', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.273 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc2026-02-12 10:02:25.273 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'e5d74080-c776-4845-a528-057e04335fa2', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.275 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}2026-02-12 10:02:25.275 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'd2817683-f838-48f8-97a4-f173961bdabc', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.276 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.2026-02-12 10:02:25.278 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'bcf70dd4-e466-4935-a198-0cf59c984ebf', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.278 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.2026-02-12 10:02:25.282 Thread-8 (_configdone_handler) udi_interface DEBUG venstarns:start: In node server start()...2026-02-12 10:02:25.284 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo2026-02-12 10:02:25.285 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '06508a20-b2e2-47f7-8d13-5484a60f48e2', 'uuid': '00:0d:b9:59:39:70', 'name': 'Sensibo', 'nsid': '2cd1ff14-8482-4947-a806-e5fa6f42f793', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1760666052837, 'timeStarted': 1770587657120, 'timeModified': 1770587665363, 'version': '2.0.13', 'edition': 'Free', 'branch': 'master', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-sensibo-poly.git', 'home': '/var/polyglot/pg3/ns/000db9593970_3', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'sensibo_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'e24dff66-902a-4401-80ed-513fc7bca3e9', 'noLicense': 0, 'latestVersion': '2.0.13', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.285 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e93316a8-833e-426f-9a15-bc37f487ae78', 'uuid': '00:0d:b9:59:39:70', 'name': 'Virtual', 'nsid': '2bc787f3-277a-42b1-839f-e85561e1604f', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1767895590458, 'timeStarted': 1770587711402, 'timeModified': 1770587718394, 'version': '3.1.26', 'edition': 'Free', 'branch': 'v3.1.2x', 'url': 'https://github.com/UniversalDevicesInc-PG3/Virtual.git', 'home': '/var/polyglot/pg3/ns/000db9593970_6', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udi-Virtual-pg3.py', 'shortPoll': 3, 'longPoll': 30, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '671a0b64-3de5-434d-a20e-350e38ee5a37', 'noLicense': 0, 'latestVersion': '3.1.26', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.286 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'a9cd23b9-ab9f-421e-9d9b-1bcca6006273', 'uuid': '00:0d:b9:59:39:70', 'name': 'VenstarCT', 'nsid': '639a432c-972f-4b09-a168-0225f01d08a0', 'expires': 1773006399000, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1770911132984, 'timeStarted': 1770912140230, 'timeModified': 1770912145163, 'version': '3.0.11', 'edition': 'Standard', 'branch': None, 'url': 'https://pg3store.isy.io/v2/nodeservers/production/venstar-pg3-3.0.11.zip', 'home': '/var/polyglot/pg3/ns/000db9593970_8', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'main.py', 'shortPoll': 20, 'longPoll': 150, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '05cc4cc4-406d-46a0-8a80-1582d54d344f', 'noLicense': 0, 'latestVersion': '3.0.11', 'dbVersion': 1} from Polyglot2026-02-12 10:02:25.286 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom2026-02-12 10:02:25.287 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'customparamsdoc': '<h2>VenstarCT NodeServer Configuration</h2>\n\n<h4>Advanced Configuration:</h4>\n\n<ul>\n<li>key: shortPoll, value: polling interval for thermostat states on the local network in seconds (default 15)</li>\n<li>key: longPoll, value: polling interval for alerts, sensor states, and runtimes in seconds (default 150)</li>\n</ul>\n\n<h4>Custom Configuration Parameters:</h4>\n\n<ul>\n<li>key: hostname, value: hostname(s) or IP address(es) for thermostat(s), seperated by semicolons, to bypass SSDP discovery (optional)</li>\n</ul>\n'} from Polyglot2026-02-12 10:02:25.287 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message customparamsdoc from Polyglot2026-02-12 10:02:29.145 MQTT udi_interface.interface INFO interface:_message: Profile installation finished2026-02-12 10:02:40.234 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-02-12 10:02:40.236 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-02-12 10:02:40.236 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-02-12 10:02:40.238 Thread-9 (_poll_handler) udi_interface INFO venstarns:shortPoll: Updating node states in shortPoll()...2026-02-12 10:02:52.618 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop2026-02-12 10:02:52.619 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop2026-02-12 10:02:52.620 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot2026-02-12 10:02:52.621 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.2026-02-12 10:02:52.622 Thread-10 (_stop_handler) udi_interface DEBUG venstarns:stop: In node server stop()...2026-02-12 10:02:52.623 Thread-10 (_stop_handler) udi_interface.interface INFO interface:stop: Disconnecting from MQTT... localhost:88832026-02-12 10:02:52.626 Thread-10 (_stop_handler) udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Normal disconnection. Sent by server: False. Retry in 10 seconds.2026-02-12 10:03:02.937 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=302026-02-12 10:03:02.938 MainThread udi_interface INFO init:<module>: UDI interface initializing2026-02-12 10:03:02.939 MainThread udi_interface INFO init:<module>: User=None2026-02-12 10:03:02.940 MainThread udi_interface INFO init:<module>: Home=/var/polyglot/pg3/ns/000db9593970_82026-02-12 10:03:02.940 MainThread udi_interface INFO init:<module>: Node Server Path=/var/polyglot/pg3/ns/000db9593970_82026-02-12 10:03:02.941 MainThread udi_interface INFO init:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTk6Mzk6NzAiLCJwcm9maWxlTnVtIjo4LCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJsMElGVS1DSmdNUDBvTmt2IiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMTEiLCJpc3lWZXJzaW9uIjoiNi4wLjQiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ==2026-02-12 10:03:02.942 MainThread udi_interface INFO init:<module>: Loading interface module2026-02-12 10:03:03.299 MainThread udi_interface INFO interface:<module>: Loading MQTT module2026-02-12 10:03:06.293 MainThread udi_interface INFO interface:<module>: MQTT module loaded2026-02-12 10:03:07.848 MainThread udi_interface INFO init:<module>: Loading udi_interface module2026-02-12 10:03:07.852 MainThread udi_interface INFO init:<module>: Loading node module2026-02-12 10:03:07.853 MainThread udi_interface INFO init:<module>: Loading custom module2026-02-12 10:03:07.854 MainThread udi_interface INFO init:<module>: Loading isy module2026-02-12 10:03:07.854 MainThread udi_interface INFO init:<module>: Loading OAuth module2026-02-12 10:03:07.857 MainThread udi_interface INFO init:<module>: UDI interface initialized2026-02-12 10:03:07.858 MainThread udi_interface INFO init:<module>: UDI Python Interface for Polyglot version 3 3.4.5 Starting...2026-02-12 10:03:07.886 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.4.11 [ISY: 6.0.4, Slot: 8]2026-02-12 10:03:07.887 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.3.82', 'netmask': '255.255.255.0', 'broadcast': '192.168.3.255'}2026-02-12 10:03:07.889 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:88832026-02-12 10:03:07.892 MainThread udi_interface INFO main:<module>: Starting VenstarCT node server...2026-02-12 10:03:07.893 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 000db9593970_8.cert key: 000db9593970_8.key ca: /usr/local/etc/ssl/certs/ud.ca.cert2026-02-12 10:03:07.930 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds.2026-02-12 10:03:07.966 MainThread udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot.2026-02-12 10:03:08.058 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success2026-02-12 10:03:08.059 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:59:39:70_8 - MID: 2 Result: 02026-02-12 10:03:08.112 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0']2026-02-12 10:03:08.168 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll2026-02-12 10:03:08.169 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll2026-02-12 10:03:08.170 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '5280b596-377f-4116-b330-a854973396f8', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customparams', 'value': '{"hostname":"192.168.3.127"}', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.172 Thread-3 (_parameters_handler) udi_interface.custom DEBUG custom:load: CUSTOM: load {'hostname': '192.168.3.127'}2026-02-12 10:03:08.173 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '4b876651-db51-462a-a395-5cfe8f28e21d', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customparamsdoc', 'value': '<h2>VenstarCT NodeServer Configuration</h2>\n\n<h4>Advanced Configuration:</h4>\n\n<ul>\n<li>key: shortPoll, value: polling interval for thermostat states on the local network in seconds (default 15)</li>\n<li>key: longPoll, value: polling interval for alerts, sensor states, and runtimes in seconds (default 150)</li>\n</ul>\n\n<h4>Custom Configuration Parameters:</h4>\n\n<ul>\n<li>key: hostname, value: hostname(s) or IP address(es) for thermostat(s), seperated by semicolons, to bypass SSDP discovery (optional)</li>\n</ul>\n', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.174 Thread-3 (_parameters_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking hostname / 192.168.3.1272026-02-12 10:03:08.175 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '354710a9-207c-4206-b98c-9bd1880bb47b', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'customtypeddata', 'value': '{}', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.176 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'e5d74080-c776-4845-a528-057e04335fa2', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.177 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {}2026-02-12 10:03:08.177 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'd2817683-f838-48f8-97a4-f173961bdabc', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.178 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server.2026-02-12 10:03:08.180 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'bcf70dd4-e466-4935-a198-0cf59c984ebf', 'uuid': '00:0d:b9:59:39:70', 'profileNum': 8, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.180 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server.2026-02-12 10:03:08.185 Thread-8 (_configdone_handler) udi_interface DEBUG venstarns:start: In node server start()...2026-02-12 10:03:08.206 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo2026-02-12 10:03:08.207 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo2026-02-12 10:03:08.208 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom2026-02-12 10:03:08.209 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '06508a20-b2e2-47f7-8d13-5484a60f48e2', 'uuid': '00:0d:b9:59:39:70', 'name': 'Sensibo', 'nsid': '2cd1ff14-8482-4947-a806-e5fa6f42f793', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1760666052837, 'timeStarted': 1770587657120, 'timeModified': 1770587665363, 'version': '2.0.13', 'edition': 'Free', 'branch': 'master', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-sensibo-poly.git', 'home': '/var/polyglot/pg3/ns/000db9593970_3', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'sensibo_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'e24dff66-902a-4401-80ed-513fc7bca3e9', 'noLicense': 0, 'latestVersion': '2.0.13', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.210 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc2026-02-12 10:03:08.212 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e93316a8-833e-426f-9a15-bc37f487ae78', 'uuid': '00:0d:b9:59:39:70', 'name': 'Virtual', 'nsid': '2bc787f3-277a-42b1-839f-e85561e1604f', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1767895590458, 'timeStarted': 1770587711402, 'timeModified': 1770587718394, 'version': '3.1.26', 'edition': 'Free', 'branch': 'v3.1.2x', 'url': 'https://github.com/UniversalDevicesInc-PG3/Virtual.git', 'home': '/var/polyglot/pg3/ns/000db9593970_6', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udi-Virtual-pg3.py', 'shortPoll': 3, 'longPoll': 30, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '671a0b64-3de5-434d-a20e-350e38ee5a37', 'noLicense': 0, 'latestVersion': '3.1.26', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.213 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'a9cd23b9-ab9f-421e-9d9b-1bcca6006273', 'uuid': '00:0d:b9:59:39:70', 'name': 'VenstarCT', 'nsid': '639a432c-972f-4b09-a168-0225f01d08a0', 'expires': 1773006399000, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1770911132984, 'timeStarted': 1770912182556, 'timeModified': 1770912188126, 'version': '3.0.11', 'edition': 'Standard', 'branch': None, 'url': 'https://pg3store.isy.io/v2/nodeservers/production/venstar-pg3-3.0.11.zip', 'home': '/var/polyglot/pg3/ns/000db9593970_8', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'main.py', 'shortPoll': 20, 'longPoll': 150, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '05cc4cc4-406d-46a0-8a80-1582d54d344f', 'noLicense': 0, 'latestVersion': '3.0.11', 'dbVersion': 1} from Polyglot2026-02-12 10:03:08.214 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom2026-02-12 10:03:08.214 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'customparamsdoc': '<h2>VenstarCT NodeServer Configuration</h2>\n\n<h4>Advanced Configuration:</h4>\n\n<ul>\n<li>key: shortPoll, value: polling interval for thermostat states on the local network in seconds (default 15)</li>\n<li>key: longPoll, value: polling interval for alerts, sensor states, and runtimes in seconds (default 150)</li>\n</ul>\n\n<h4>Custom Configuration Parameters:</h4>\n\n<ul>\n<li>key: hostname, value: hostname(s) or IP address(es) for thermostat(s), seperated by semicolons, to bypass SSDP discovery (optional)</li>\n</ul>\n'} from Polyglot2026-02-12 10:03:08.215 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message customparamsdoc from Polyglot2026-02-12 10:03:09.227 MQTT udi_interface.interface INFO interface:_message: Profile installation finished2026-02-12 10:03:22.569 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-02-12 10:03:22.570 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll Edited February 12Feb 12 by apostolakisl
February 12Feb 12 FWIW I had several different color touch stats going back over 10 years including the T7850sI had these stats in the nodelink days, and query/status is the 'bread and butter' of the api. I used the browser a lot to discover things and debug problems. If that's not working from a browser, I don't see pg3 having luckThey can have pin settings, is that being used or maybe set unintentionally?
February 12Feb 12 I have two T7900's with built-in wifi, and a T6800 with the plug in wifi dongle. The plugin sees the T7900's but not the T6800. Skyport sees all three. There must be differences in the data format from the different thermostats.
February 12Feb 12 Author 3 hours ago, paulbates said:FWIW I had several different color touch stats going back over 10 years including the T7850sI had these stats in the nodelink days, and query/status is the 'bread and butter' of the api. I used the browser a lot to discover things and debug problems. If that's not working from a browser, I don't see pg3 having luckThey can have pin settings, is that being used or maybe set unintentionally?No pin is set. The thermostat is not locked, anyone can walk up and change the settings. ChatGPT saysSo now we have:/ → works/query/sensors → works/query/status → hangsThat means:✅ Web server is fine✅ API framework is running✅ Sensor subsystem is responding❗ The status handler specifically is blockingThis is not a network problem.It’s not VPN.It’s not UniFi.It’s not DNS.This is almost certainly the thermostat blocking while trying to assemble the full status payload.Why /query/status Is Special/query/status pulls:Equipment stateHeat/cool stage statusFan stateModeSchedule statusPossibly cloud statePossibly accessory state (humidifier, dehumidifier, etc.)If any one of those internal calls hangs, the entire endpoint never returns./query/sensors is simpler — it only pulls temperature/humidity inputs.The Most Likely CauseAfter firmware update:One internal module didn’t restart cleanlyOr the equipment interface process is stuckOr there’s a bad state flag from the updateThis is classic “partial subsystem deadlock.”What Will Fix It (Almost Certainly)A full cold power pull.Not menu reboot.Physically remove it from the wall for 60+ seconds.The T7800 WiFi module does not fully reset on soft reboot.Why Skyport WorksSkyport uses:Outbound connectionDifferent internal status routineNot the same HTTP handlerSo cloud working does NOT mean /query/status will work.Extremely Important QuestionIs the thermostat currently:Actively heating or cooling?Calling a stage?In auto mode?Connected to any accessories?Because I’ve seen /query/status hang when:A stage output is misconfiguredA heat pump reversing valve state is weirdAccessory configuration doesn’t match hardwareNext StepsWhen you’re onsite:Power pullImmediately test /query/statusIf it works → doneIf it still hangs → we dig into configuration (not networking)It says to power cycle. Whish is certainly a descent idea. I'll do it later today.
February 12Feb 12 Author I just installed a second Venstar T7850 this time. Same exact thing.So either there is some setting on the thermostat I am not setting correctly, or something is up with the node.
February 12Feb 12 Author Chat GPT thinks it is the v5 firmware. It thinks when skyport is connected it restricts the local api. I don't know. I don't know how to get the older firmware to try. I suppose I can try disconnecting skyport.
February 12Feb 12 There are settings way down in the stat menus for disabling/enabling the local api... my money's on that one.
February 12Feb 12 I have latest firmware on mine and use the skyport app and via the plugin. It’s been years since I set it up using nodelink and then migrating them to the Venstar Ct plugin but all I recall was having to authorize the local api. On thermostat it’s under WiFi enable local api. Probably can do it via skyport app too.
February 12Feb 12 Author @paulbates @hart2hartThe local api is enabled on both of them. It was off by default and I clicked to turn it on. There is a second line that is greyed out that says it is http.If local api were off, I'm not sure I would get anything when I go to the url. For exmple, if I do a sensor query I get this.{"sensors":[{"name":"Thermostat","temp":73.0},{"name":"Space Temp","temp":73.0}]} Edited February 12Feb 12 by apostolakisl
February 12Feb 12 Did you just turn them to enabled now and they still don’t discover in plugin? If so I’d find the option in thermostat menu to restart them. Are all three joined to a secure WiFi access name? If the one saying http is not it sounds like it’s saying secured access is required.
February 13Feb 13 Author 1 hour ago, hart2hart said:Did you just turn them to enabled now and they still don’t discover in plugin? If so I’d find the option in thermostat menu to restart them.Are all three joined to a secure WiFi access name? If the one saying http is not it sounds like it’s saying secured access is required.Yes, they are all on the same network as the polisy and of course the wifi is password secured, though that shouldn't have anything to do with anything. They connect to star net and I can ping them and I can go to the http:// address of the units and get a response. Lots of things on that network that polisy connects to fine. I set them to enabled local api right away when I first configured them. I have rebooted the one via a full 60 seconds power down. The http is just the venstar reporting that it is not requiring authentication for the api. I imagine yours says the same thing. Both of mine are identical on the page that toggles the api on/off.
February 13Feb 13 I wasn’t suggesting your WiFi was not password protected. I was suggesting they might be connected to different SSIDs and one of the ssid was setup on its access point without choosing encryption in its setup. None of mine say http.
February 13Feb 13 Author Polisy isn't connected to wifi, it is hard wired, only the thermostats are connected to ssid's. They are all on the same corporate vlan. No firewalls between devices. From a pc on the same vlan I get responses from the IP address of the thermostats. The manual also shows that it has options to http vs https. But once you turn on api, it greyed out to http. Perhaps https could be selected first and then you turn on api?5 minutes ago, hart2hart said:I wasn’t suggesting your WiFi was not password protected. I was suggesting they might be connected to different SSIDs and one of the ssid was setup on its access point without choosing encryption in its setup.None of mine say http. Edited February 13Feb 13 by apostolakisl
February 13Feb 13 Author 10 hours ago, hart2hart said:Can you ping the thermostats from the Polisy?yes, I can ping both of them. Mostly the response times are in the 5-10ms, though a few are much longer.EDITAnd I get a response on port 80. Not sure if I should check any other ports. Edited February 13Feb 13 by apostolakisl
February 13Feb 13 Not much I can do to help. You said you’d installed latest FW. FWIW mine are at 6.93.
February 13Feb 13 Author I changed the T7800 to https and set a username and password. Nodelink when set to http gave the error that the connection was refused. I changed to https and added the username and password and now the error is a timeout error. So it seems that the thermostat is accepting the https authorization but then ignoring whatever command nodelink is issuing to it. I can only assume that there is something going on with a firmware mismatch. Edited February 13Feb 13 by apostolakisl
February 21Feb 21 Author Today, I tried hit "discover" again, and for whatever reason, it finds the t7850 thermostat. The one that was working with nodelink. Still not finding the t7800 with the wifi adapter. I have no idea why today it is finding the one thermostat when it wouldn't before. I changed nothing.
February 22Feb 22 Author Both units are working now. I don't know why. The only thing I know of is that we had a circuit breaker pop that caused the wifi AP and managed switch that these thermostats use to reboot. But I find it hard to believe that this was fixed by that. Everything else on those devices worked fine before and after and I was able to get responses on port 80 doing "curl" queries from the polisy.
March 12Mar 12 Author I now have 3 connected Venstar thermostats. I just added a 4th, and it won't connect. This makes no sense. Two of the others also wouldn't connect, then one day out of the blue they started connecting. The 3rd unit discovered immediately. I do not understand this. I ask the thermostat to do a firmware update and it says it is already up to date. The others supposedly were also up to date. Perhaps some update is actually happening after being online for a while even though it says not? Two of the connected thermostats are t5800 with wifi key, and one is a t7850 with built in wifi. The 4th is also a t5800 with a key. All of them are connected to the Venstar skyport server without issue.
March 12Mar 12 I have two T7900's and one T5800 with the wifi dongle. I've never had the T5800 show up in the plugin. But they work fine with skyport. One of the T7900's has always been hard to get to connect to skyport. Works for a while, but if power cycled, won't reconnect.I've never had an over the air firmware upgrade work. Venstar sent me a SD card with the upgrade files on it, which I keep preciously for that purpose, since the card must not exceed a certain capacity that is now largely outdated.
Monday at 05:08 PM1 day Author I just noticed in nodelink that the two t5800 with dongles that aren't connecting are reporting the thermostat type and firmware to nodelink. Nodelink shows that info, but it does not show any data. I did a curl query to one of the thermostats that doesn't connect and the same to the one that does, and the one thermostat gives a response, the other doesn't. It seems as though the local api is off, despite being on.C:\Users\apostolakisl>curl 192.168.3.89:80/query/info{"name":"AHU3 153434240000000000bby","mode":3,"state":0,"fan":0,"fanstate":0,"tempunits":0,"schedule":1,"schedulepart":1,"away":0,"spacetemp":73.0,"heattemp":67.0,"cooltemp":76.0,"cooltempmin":35.0,"cooltempmax":99.0,"heattempmin":35.00,"heattempmax":99.0,"setpointdelta":2.0,"availablemodes":0}C:\Users\apostolakisl>curl 192.168.3.127:80/query/infoC:\Users\apostolakisl>CHAT GPT said this:What’s happening internally on your Venstar T5800 is likely:HTTP connection acceptedRequest handed to handler threadHandler tries to process route (/foobar, /query, etc.)Handler crashes / times out internallySocket closes with no response → curl shows empty reply👉 That delay = the thermostat is attempting to process the request and failing, not ignoring it.chat gpt basically wants me to do a hard reset. it thinks the api subsystem is locked up. if that fails, do a factory reset. This is consistent with me having issues with other thermostats that somehow stopped having issues.@Guy Lavoie The SD card just needs to be between 2 and 16GB and Fat32 formatted. I use a micro SD and an adapter. You can download a tool from venstar that puts the firmware and any custom images you want onto the card.
Monday at 08:37 PM1 day My experience with the color touches was nodelink and that was a very good experience. I only stopped using them because I moved from that house and left them and the system there. What I recall about the API is how transactional it is, meaning it's only as good as the last call to it. I would not be confident about it juggling more than one client at a time.The question is, are you simultaneously connecting to the same stat with both nodelink and the Venstar plugin? The hardware/linux in the colortouch series is pretty limited. If "yes", I would stop one of the the 2 clients, pull the stat off of the wall to reset it and try again,
Monday at 08:47 PM1 day Author 6 minutes ago, paulbates said:My experience with the color touches was nodelink and that was a very good experience. I only stopped using them because I moved from that house and left them and the system there.What I recall about the API is how transactional it is, meaning it's only as good as the last call to it. I would not be confident about it juggling more than one client at a time.The question is, are you simultaneously connecting to the same stat with both nodelink and the Venstar plugin? The hardware/linux in the colortouch series is pretty limited. If "yes", I would stop one of the the 2 clients, pull the stat off of the wall to reset it and try again,There are no clients connected to the ones that won't connect. The ones that will connect have no issue being connected to nodelink and pg3 at the same time and accepting manual queries. The ones with no cleints connected won't respond to manual query commands either. I tried connecting to only 1 thing, then if it didn't work tried the other thing. I agree with chatpgt analysis that the thermostats' public api engine is crashed/frozen/whatever word you want to use. It is clearly on but not responding to anything but simple commands.
