20 hours ago20 hr I know there's' a lot in this thread .. Does shutting skyport cloud api from the thermostat's menu help? Skyport cloud had growth issues +10 years ago and it trampled on local activity sort of like you're describing.
18 hours ago18 hr Author 2 hours ago, paulbates said:I know there's' a lot in this thread ..Does shutting skyport cloud api from the thermostat's menu help? Skyport cloud had growth issues +10 years ago and it trampled on local activity sort of like you're describing.Possible. I factory reset the two that aren't working, connected to wifi and turned on the local api, and I got a connection on nodelink (didn't try pg3x at that point). I thought I had it fixed, I then rejoined skyport thinking I was good. When I went back later to check on it, it was no longer working. So maybe I need to leave skyport off.
16 hours ago16 hr Author @paulbates Seems that you are correct. I factory reset again, setup wifi, turned on api, and they are both working with nodelink and pg3x. I will let it go for a few days and then see what happens if I try connecting to skyport.
