Wednesday at 08:23 PM5 days Program 'Alarm!!+’ not working:'Alarm!!+' Program – Enabled is checked and program savedWhat is supposed to happen: If Insteon sensor switched ON, Set scene 'ALARM_All_Lights' = ONPolisy Log – Sensor is switched ON - see attachedScene ‘ALARM_All_Lights’ does not turn on when sensor is switched onIf I manually execute the 'Alarm!!+' ‘Run Then’ the Scene turns on and notifications are sentGhosts in the machine... What could be wrong?ThanksStew Progam not working on sensor control - switched to ON 20260218.docx
Wednesday at 10:51 PM5 days Author An Insteon IOLinc v.41 is connected to my alarm relay outputs. When the Alarm is tripped, the relay output closes. The IOlink registers the closure of the circuit and Polisy recognizes the switching to 'closed'. I have verified that the AC console reports the IOLinc circuit closure when the alarm is tripped and reports the circuit opening when the alarm is cleared.
Wednesday at 11:08 PM5 days Author '12129Td/Alarm/ALARM - Intrucsion-Sensor' is switched On.BTW - This worked about a year ago. Recently the house alarm tripped and I realized the ALL Lights scene was not turning on.
Wednesday at 11:30 PM5 days The IOLinc is a powerline only device, if you have noise on the powerline at the time the alarm triggers the IOLinc may not send its status..Can you put the controller log into level 3 mode and then set off your alarm and post a copy of the log. Edited Wednesday at 11:31 PM5 days by Techman
Wednesday at 11:38 PM5 days 26 minutes ago, SSamuels said:'12129Td/Alarm/ALARM - Intrucsion-Sensor' is switched On.BTW - This worked about a year ago. Recently the house alarm tripped and I realized the ALL Lights scene was not turning on.So it's looking for the control event, therefore it's not a status change issue. If you're seeing the status update in admin console then it's certainly getting the control event.
Thursday at 12:18 AM5 days Author Level 3 log ISY-Events-Log.v6.0.4__Wed 2026.02.18 04.17.06 PM.txtThe IOLinc's address is 42.4.E3
Thursday at 01:32 AM4 days Your controller is seeing the status of the IOLincWhen you trigger the alarm does your program, '12129Td/Alarm/ALARM - Intrucsion-Sensor' show as red or as green in your program tree? You might also try deleting and recreating the program.
Thursday at 01:57 AM4 days Author When the alarm is trigged the program is Green.I will try deleting and recreating.Thanks
Thursday at 11:16 AM4 days 9 hours ago, SSamuels said:When the alarm is trigged the program is Green.Unless your program runs false, it will always show as green. I am not sure that we can conclude anything from this. Instead, I would look at the program summary tab and see when was the last time the program ran. If the time does not match that of the most recent alarm trigger, then it did not see the signal.Given the evidence (log and IOLinc status) suggests that the Polisy IS receiving the IOLinc status, have you checked to see if the program somehow became disabled? Is the program in a folder that somehow because disabled? Edited Thursday at 11:17 AM4 days by oberkc
Thursday at 01:27 PM4 days Based on the log, your iolinc is triggering program 0015. Immediately after the trigger, the isy is turning on group (scene) 47. This appears to be a very large scene with 40+ members (I lost count)The program and scene appear to be executing correctly. Can you plm communicate reliably with these devices? The plm appears to hear other devices. Can it transmit to them?
Thursday at 02:42 PM4 days @SSamuels Let me known if deleting and recreating the program fixed your issue
Thursday at 04:03 PM4 days Solution @SSamuels Sometimes the easiest solution to try first is to go to the program, make any adjustment that will require re-saving the program. Try that before you get to involved in other solutions since you said that the MD is triggering and the program runs if yo manually run it. Similar to what @Techman suggested above but w/o the need to recreate the whole thing.
