Notification Sounds
How do I add a sound for each notification?
Example:
I have a notification for daily test, no change necessary
I have a notification for burglar alarm. I want my phone to make a siren or alarm sound
Not sure how to make or set sounds.
John
On 2/23/2026 at 6:15 PM, Geddy said:
@JSchumann the wiki lists what sounds are available:
https://wiki.universal-devices.com/UD_Mobile#Sounds
So I do this: Upon receipt of the notification long click the notification displayed by Android, this will show Android Notification Settings. Press settings (gear icon). Then click on any of the notification types (sound names), then click Sounds, THERE is no Select Sounds after pressing the fear icon........See attached image......now select a sound from your device.
On 2/23/2026 at 6:11 PM, atmarosi said:
This is where I set it:
Didn't work on my Android.....
I'm not an Android user so can't help specifically. My guess is the settings have changed since the wiki was written. Perhaps other Android users can chime in or @Javi might have an update to this.
So people know how to help what version Android are you running?
What IoX version are you running (please give actual version number - check here: https://eisy.local:8443/WEB/sysconfig.txt and look for ISY-6.0.4_x )
@JSchumann
If you scroll down you should see a line for Notification Cateagories. Clicking on that line will give you more options. If you don't have a line for Notification Categories then you probably have no options for additional sounds
isy-6.0.4_1
Version : 6.0.4_1
Installed on : Fri Jan 9 14:25:07 2026 EST
Android Version 16, One UI 8.0
2 hours ago, Techman said:
@JSchumann
This is what I get for Notification Settings, what do I do with this????
