Monday at 10:43 PM2 days How do I add a sound for each notification?Example:I have a notification for daily test, no change necessaryI have a notification for burglar alarm. I want my phone to make a siren or alarm soundNot sure how to make or set sounds.Thanks,John
Monday at 11:15 PM2 days @JSchumann the wiki lists what sounds are available:https://wiki.universal-devices.com/UD_Mobile#Sounds
Yesterday at 01:19 AM1 day Author On 2/23/2026 at 6:15 PM, Geddy said:@JSchumann the wiki lists what sounds are available:https://wiki.universal-devices.com/UD_Mobile#SoundsSo I do this: Upon receipt of the notification long click the notification displayed by Android, this will show Android Notification Settings. Press settings (gear icon). Then click on any of the notification types (sound names), then click Sounds, THERE is no Select Sounds after pressing the fear icon........See attached image......now select a sound from your device.
Yesterday at 01:35 AM1 day Author On 2/23/2026 at 6:11 PM, atmarosi said:This is where I set it:Didn't work on my Android.....
21 hours ago21 hr 15 hours ago, JSchumann said:THERE is no Select Sounds after pressing the fear iconI'm not an Android user so can't help specifically. My guess is the settings have changed since the wiki was written. Perhaps other Android users can chime in or @Javi might have an update to this.So people know how to help what version Android are you running?What IoX version are you running (please give actual version number - check here: https://eisy.local:8443/WEB/sysconfig.txt and look for ISY-6.0.4_x )
16 hours ago16 hr @JSchumann If you scroll down you should see a line for Notification Cateagories. Clicking on that line will give you more options. If you don't have a line for Notification Categories then you probably have no options for additional sounds
14 hours ago14 hr Author 6 hours ago, Geddy said:I'm not an Android user so can't help specifically. My guess is the settings have changed since the wiki was written. Perhaps other Android users can chime in or @Javi might have an update to this.So people know how to help what version Android are you running?What IoX version are you running (please give actual version number - check here: https://eisy.local:8443/WEB/sysconfig.txt and look for Iisy-6.0.4_1Name : isyVersion : 6.0.4_1Installed on : Fri Jan 9 14:25:07 2026 ESTAndroid Version 16, One UI 8.0
14 hours ago14 hr Author 2 hours ago, Techman said:@JSchumannIf you scroll down you should see a line for Notification Cateagories. Clicking on that line will give you more options. If you don't have a line for Notification Categories then you probably have no options for additional soundsThis is what I get for Notification Settings, what do I do with this????
12 hours ago12 hr Click on one of the sounds, then enable it.You'll probably have to write a program to apply the sound to an event. UD Mobile - Universal Devices, Inc. Wiki
