March 4Mar 4 I dont a migration from my isy994. I been having so many problem from the system stying bust to trying to link its for hours. Now That that has stooped on have of the device insteon devices woek. I have rewote to the try retstore them and yet nothing. I going to pull my hair out been on this for days now.
March 4Mar 4 Did you clear your java cache checking all 3 boxes, and download the IoX Launcher from here: https://isy.universal-devices.com/start.jnlpIn the admin console, under "Files", do a "Restore Devices" Edited March 4Mar 4 by Techman
March 4Mar 4 Migrating from a ISY994i to a eisy? Is it just Insteon devices or also Zwave? Did you keep the same PLM, using a serial to USB adapter?
March 4Mar 4 Author only Insteon and samae plm usb, And yes I did restore devices several times. Edited March 4Mar 4 by danncas add on
March 4Mar 4 I'm guessing that "That that has stooped on have of the device insteon devices woek" means half of the devices work? If so, are the non working ones battery powered devices, like leak detectors or open close sensors? If that's the case, you might need to relink those manually.
March 4Mar 4 Author finally got it migrated with out error BUT NOW IT SAWE PLM NOT CONNECTED. BUT IT IS?????
March 4Mar 4 Try powering off your eisy for a few minutes, then turn it back on. Then log back in and see if the PLM now shows as responding ok.
