ZWave LR support
Apologies if this is covered, my search was inconclusive.
My controller appears LR-aware internally and I am able to add using DSK value, but I don’t see any user-facing way to enable or verify LR. Is LR currently supported on eisy, and if not, is it planned? I have a single device that would benefit.
TY
To use Zwave LR the device must be included with S2 AUTHENTICATED security enabled.
Unfortunately I haven't found a way to determine if a device was installed as Mesh or LR as the include process doesn't appear to offer that option
Found this on the web:
SmartStart Requirement: Z-Wave LR requires inclusion via SmartStart (scanning a QR code). If you added the device using the "classic" manual pairing method (pressing a button on the device), it was almost certainly added as a standard Mesh node.
Well I added a Weiser lock using it's PIN code (printed next to the QR code). The node title shows "Door Lock [S2 Access] [S0]"
Just now, Guy Lavoie said:
When adding it by pressing the pairing button, a pop up appeared in admin console saying the lock was requesting S2 security, with a checkbox for both S0 and S2 (both checked). It would only let me proceed with the S2 box checked if I entered the PIN code.
Edited by Guy Lavoie
I have started using smart start via the UD iPhone app which lets you scan the QR code, and I choose s2 when I am offered the choice. I have not been able to determine if it joins the device as a p2p link or mesh.
I have read Michel comments that there is no official support, I am just trying to understand if there is comm/protocol support for LR since I have a use case that may require it.
thanks for feedback and info.
Edited by walkman9999
Typo
