INIT TO causing variable to be zeroed out
I have this program that I am trying to use to set an integer variable to the current day of the month. When I run the THEN clause the INIT value is correct but the variable iCurrentDayOfMonth is set to zero. This doesn't make sense. I expect them both to be the same. I have a couple of other similar programs using different variables and they work fine. What is going on? TIA
DATTM SetCurDayOfMonth - [ID 0047][Parent 0028]
$iCurrentDayOfMonth = [Current Day of Month]
$iCurrentDayOfMonth Init To $iCurrentDayOfMonth
Whereas these programs work fine. Both the variables and its INIT values are correct all the time:
DATTM SetCurHH - [ID 006D][Parent 0028]
Repeat 23 times
$iCurrentHH = [Current Hour]
$iCurrentHH Init To $iCurrentHH
Run Program 'DATTM SetCurMM' (Then Path)
Wait 1 hour
DATTM SetCurMM - [ID 006E][Parent 0028]
Repeat 59 times
$iCurrentMM = [Current Minute]
$iCurrentMM Init To $iCurrentMM
Wait 1 minute
EISY running version 6.0.0.
OK, how do I paste code into a forum post and keep the indenting? For some reason it appears to be all shoved to the left and indenting is lost. If I post the same clipboard into Notepad the code appears indented.
Thanks for any tip you can provide.
