PG3 Kasa TP-Link Node Server Beta 3.3.4
I have lots of issues. First I had both the beta and the production installed because some new device types were not supported.
I accidentally deleted the production instead of the beta so I reinstall it.
Now the production is seeing only 10 of my 17 devices. I attached that log.
Then I updated to 3.3.4
The 3.3.4 is giving authentication errors but I know its correct. Its different IP's so its almost like it wont find those devices.
So it to has only 10 devices now. Whats going on?
(Beta log attached here...will have to do second post due to limits for Production log)
Kasa_BETA-5-12-2026_34906_PM.zip
production log
Kasa-PRODUCTION_5-12-2026_34736_PM.zip
actually only 6 missing devices in BOTH beta and production. Maybe this helps (See screenshot)
These happen to be older devices.
If I can get them to work with new version I dont need the old 3.1.4.
Or worse case I buy new devices.
from logs and AI check-
Working HS103 devices:
  • 172.16.1.163 — HS103 hardware v3.0
  • 172.16.1.164 — HS103 hardware v3.0
These use the older Kasa local protocol on port 9999, so the plugin can talk to them directly.
Problem HS103 devices:
  • 172.16.1.159 — HS103 hardware v5.0
  • 172.16.1.189 — HS103 hardware v5.0
Skipped as unsupported:
  • 172.16.1.189 HS103 v5.0 — KLAP
  • 172.16.1.159 HS103 v5.0 — KLAP
  • 172.16.1.180 EP10 — KLAP
  • 172.16.1.188 EP10 — KLAP
  • 172.16.1.187 EP10 — KLAP
  • 172.16.1.186 EP10 — KLAP
  • 172.16.1.228 EP25 — KLAP
also the surge strip only shows 1 node so I cant control the individual ports.
Its an older one.
Is there one you support now?
I'll check mine when I get back from vacation. Impossible to know what really works without actually having the same model/hardware/firmware version. Which is exactly why I refuse to use Kasa for most important things. But I do like their power strips and led strips.
