Using Query in a Program
Guys --
Can someone give me a real world example of using the "Query" option of a control in the then portion of a program.
Hi Mark,
During the daytime I run a query on my outside lamps. If one is inadvertently switched on, the periodic query will pick it up and trigger the Daytime Status program.
Note that this is really a belt and suspenders approach. It the Switches are communicating properly, the Daytime Status Program should detect the on condition itself and shut the lamps down after 2 minutes.
Outside Daytime Poll
       From    Sunrise +  1 minute
       To      Sunset  - 10 minutes (same day)
   And Time is Last Run Time for 'Outside Daytime Poll' + 30 minutes
       Set Scene 'SC Outside Sunset' Query
Daytime Status Off Program
   And (
            Status  'Entry Deck' > Off
         Or Status  'Mud KPL 1 - Entry Garage' > Off
         Or Status  'Entry Patio' > Off
         Or Status  'Entry Porch' > Off
       Wait  2 minutes
       Set Scene 'SC Ouside Night' Off
Mike,
Thanks for the response, so what is the following line of code exactly doing:
I am not able to wrap my head around the Query function.
I think that its part of the set command is what makes it confusing. Its not setting anything in the devices its just querying for their current status so the ISY is in sync with those devices. And in this example it will be querying only the ones in that scene.
Hello MarkGram,
MarkSanctuary nailed the explanation - I am requesting a status update of the members of my "Outside sunset" scene. If one of these devices comes back with a Status of > Off, it will trigger the second program to turn them off after 2 minutes. I do this to ensure that I don't have outside lights burning during the Day (infuriates me).
As I had stated previously, this is a backup (may not be required for most installations). If the insteon system is working properly, the ISY will know whether the lights are on without the separate Query.
I did this because I am using dimmable CFL's for my outside lights. These bulbs generate a lot of noise at lower Dim levels. The noise also varies with outside temperature.
I had a number of occasions during the past winter when the Switches would not respond to the initial off command due to morning temperatures below -10F. The query program is a backup to repeatedly sample/turn off the lights prior to my returning home from work (saves on burst blood vessels in my brain).
So basically, the Query key word forces the ISY to re-poll the devices in that scene, right?
