2 hours ago2 hr Can someone explain better how to connect to the Eisy to the Somfy URTSii serial interface so the that I can use this Plug in? Currently I am using an Somfy Dry Contact interface with a Insteon I/O that I control with EISY, along with an elk Open Close RF transmitter to determine if it's closed or not. Only control is on or off so would like better control.
2 hours ago2 hr I have a URTSI-II. I connect to it using a Lantronix EPS1 print server. I set up the EPS1 for a raw TCP connection to it's serial port. In fact I'm also using a EPS1 to connect to my Elk M1 with the Elk plugin. Years ago I picked up a dozen of these on ebay for $5 apiece. Lots of them on ebay even now.The plugin allows you to specify a IP address and port for TCP connections. For a EPS1, the serial port is port 3001.You could also use any other device server that offers a raw TCP connection. Most do. Edited 2 hours ago2 hr by Guy Lavoie
