polylotp3 log in
here is the question. I can get to the web page but I cant log in. IT FAIL isnt the login the same as my login for my eisy? If so it rejectsiot
@danncas for the 3000 port connection it should be the same user/pass as the admin console. It’s been mentioned that once your eisy is updated to 6.x that you should only access the plugins via the eisy ui. So drop the port number and just try to access eisy ui. Going that way will use the portal credentials.
There is a change in how plugins are managed and logging into the IoX system and if you change between eisy ui and polyglot logins it could cause issues with some plugins. This is the reason UD has been suggesting only using the eisy ui now.
