Where in eISY are VLANs set?
Many months ago, I set up VLANs for the various things stuck on my LAN separating video and home automation. The full conversation for all devices has not been completed.
Yesterday, I did an update all modules as I was behind a bit on PG3. I think there were some minor updates to IoX. Anyway, after a reboot, my eisy could not be found! Logged in via the cloud and found my IP was now in one of my VLANs!! Weird! It was always in the default VLAN prior to this reboot and it has been updated and rebooted several times since the VLANs were created and my switches configured. The eisy is still in the defualt VLAN port. Again, it hasn't changed in several prior reboots but suddenly it deceided it liked the Video VLAN!!
Any thoughts on how this occurred and where I add VLAN assignments to the eisy! It's fine where it is for now, but this kind of freaked me out.
John
Edited by johnjces
The network router / switch decides that. Devices get their vlan assignment during authentication:
  • Wireless devices are assigned and routed when they have successfully authenticated
  • ET ports assignments and routes are set by the router or managed switch they are plugged in to, and the device gets what it gets from that network side assignment
My managed switches were all set up well but in some linux distros you can create VLAN interface using connection manager. Just wondering if it could be set in the eisy ...but in any event, my managed switch went wonky...failing and it has died. Ports went weird and now VPN is even down! Argh.
Oh well!
John
