Need some help - trying to create a clickable messg
Hi Folks,
Im looking for suggestions (or to hear if it possible). I purchased the Jimbos notification server, and pushover and callmebot. Im trying to set up a situation related to my water sensors.
1) I have several insteon water sensors, and if they trigger, I get a notice saying which one. What I would like to add to that notfication is a link that would trigger the main water valve to close in the house (Its a Zooz Titan Water Valve).
The theory being that I want to have control over whether that valve is closed or not. Is there any way to accomplish this either on pushover (preferred) or callmebot?
Thank you
Alex
6 hours ago, agoltz said:
Hi Folks,
Thank you
Alex
Well, I think the safest bet would be to programmatically close the water valve whenever there is a leak alarm. What happens if you fail to hear the notification in a reasonable timeframe?
If you rally want manual control and you use UD Mobile, just set up a favorite icon that will close the valve. That way you still have the ability to manually close the valve, without requiring a link.
