EISY is not online
Interesting problem here that has popped up today. Everything worked yesterday.
Amazon Echo integration failed. So I went to IoX to see what was up. It couldn't find the EISY (I was planning a reboot). When I entered "https://eisy.local:8443/desc", it sees the uuid for the device (matches what shows in the my.isy.io portal). I can't login (it doesn't respond when I click File->Login) and the three tabs are all empty.
I did a power off/power on.
No joy. IoX still can't find it. my.isy.io sees the device and firmware level (6.0.5), but any attempt to connect or do anything yields "ISY is not online" (note, it's an EISY).
UD Mobile says:
System: EISY
ERROR: Requested ISY not online. 503
System not online or not communicating with Universal Devices Portal. Verify your System is connected to the network. Try reboot.
But, I can connect to it directly using my browser, by going to the IP address and logging in. I get the eisy-ui. I can turn nodes on and off using eisy-ui. So it appears the device is working
eisy-ui tells that I'm running:
PG3x Version 3.3.22
Status: Connected
Frontend Version: 3.3.22
IoX Version: 6.0.5 Connected
Uptime <about an hour since I power off and back on>
Suggestions???
You can also try deleting Java files and apps, and then downloading a new start.jnlp from UD. Don't use a previously saved one.
Let's back up a little. The my.isy.io portal says it can't connect when I try anything, such as checking Amazon Echo integration (Message: "ISY is not online"). UD Mobile says it can't connect (Message: "System: EISY, ERROR: Requested ISY not online. 503")
Neither of those can be related to how I enter the URL in the ISY finder, or any cached Java files.
There's something deeper going on here between the ISY portal (and UD Mobile) and the device. IoX not finding it seems to be a symptom, not a cause.
So trying it with the ip address in the finder url still doesn't work?
Sounds like some kind of networking issue, in the eisy or the network. Have you been running 6.0.5 for some time already?
You are correct, I totally missed the boat with this one......
If your eisy is showing offline in the portal (there is no green dot next to the UUID), then we can forget about everything else that is not working. Nothing is going to work until this gets corrected.
Sign in to the portal, go to Tools and the drop down for Select Tools. Next highlight Information, followed by clicking on ISY Portal Access License.
You will get a popup window. Under License Active, does it indicate Yes? For License Expiry Date is it in the future or has it passed?
I suspect your license may have expired. If not, I would suggest opening a ticket with UD.
Expires next summer. When I'm home, I'll try the router reboot.
Then open a ticket if necessary.
Thanks for giving it a go.
So here's the result.
Rebooted my router.
It works now. Immediately.
For what it's worth, it's a Rockpi running FriendlyWRT.
I have no explanation. The router had been up without a reboot for months if not more. So, who knows. I apologize for not doing that immediately. It just never occurred to me that it could be a cause.
¯\_(ツ)_/¯
