Struggling with eISYIR Node Server
After a couple years of hesitation I finally migrated my ISY to the eISY. At this time I am using the 1 free month of several node servers like eISYIR to make sure everything works. Unfortunately, I have struggled with the eISYIR node server. The receiver just doesn't want to recognize remote IR signals. Here is my setup:
-EISY r1
-Harmony Elite Remote
-Harmony Hub w/ mini blasters
-Flirc USB dongle
As of lately I am not able to get the system to recognize any of the IR signals after the nodes are created (yes, they get created, then nothing). I have tried changing the Release Threshold with no luck. I have even read that line noise may be an issue, so I plugged my EISY into a power conditioner. My next option is to buy another Flirc, but I doubt this is the issue as setting the unit up on my computer works flawlessly.
adding @firstone with the hopes he can help with my setup. Any other suggestions?
PM Log package to me, please. Put it into "debug" mode, do some key presses and then generate log package. If nodes are created, there should be SOME activity.
Thanks to firstone for solving my issue.
In the event anyone else did what I did. Don't use mini-IR blasters to send signals to the Flirc. In my case the mini's did not put out a strong enough ir signal.
Ultimately, I had to do some re-organization and put the eISY & Flirc right next to the Harmony hub. This pretty much solved the issues.
