Monday at 02:25 PM3 days Have a theory. I have intellicenter. The login to that is my email with password. So I think its looking for a different login which I dont have. Any other ideas let me know!!Devices we haveIntellifloColorsyncIntellichlor - controlled by IntellichemIntellichemUltraTempSmart Valve for SlideAlll work fine in their app and on their intellicenter2 website.Jeff2026-08-24 10:18:26.673 Thread-3 (custom_params_handler) udi_interface INFO pentair:authenticate: Pentair Cloud authentication successful2026-08-24 10:18:26.875 Thread-3 (custom_params_handler) udi_interface INFO pentair:discover_devices: Pentair account returned 0 device(s)2026-08-24 10:18:26.875 Thread-3 (custom_params_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud Reporting set ST to 1 to Polyglot2026-08-24 10:18:26.875 Thread-3 (custom_params_handler) udi_interface.node DEBUG node:reportDriver: Updating value to 12026-08-24 10:18:26.881 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'address': 'controller', 'driver': 'ST', 'value': '1', 'uom': 25, 'text': None}]}2026-08-24 10:18:26.912 MQTT udi_interface.interface INFO interface:_message: Successfully set controller :: ST to 1 UOM 252026-08-24 10:18:27.073 Thread-3 (custom_params_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud No change in ST's value2026-08-24 10:18:37.888 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-08-24 10:18:37.888 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-08-24 10:18:37.888 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-08-24 10:18:38.129 Thread-5 (poll_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud No change in ST's value2026-08-24 10:19:37.891 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-08-24 10:19:37.891 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-08-24 10:19:37.891 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-08-24 10:19:38.087 Thread-6 (poll_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud No change in ST's value2026-08-24 10:20:37.892 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-08-24 10:20:37.893 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-08-24 10:20:37.893 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-08-24 10:20:38.165 Thread-7 (poll_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud No change in ST's value2026-08-24 10:21:37.894 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll2026-08-24 10:21:37.895 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll2026-08-24 10:21:37.895 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot2026-08-24 10:21:38.106 Thread-8 (poll_handler) udi_interface.node DEBUG node:setDriver: controller:Pentair Cloud No change in ST's value
Monday at 05:38 PM2 days @macjeff The possibility is that you are using a different account than your stuff is registered to. Logging out of your account on your phone app and then logging back in manually entering the same username and password that you used in the plugin will test that.The second is maybe more likely and that is you are using a different system that runs everything behind intellicenter. I really don't know the details on how pentair has evolved their system. Currently, I believe they have gone to a system where the devices all connect directly to the cloud, but you may be on a system that everything connects through intellicenter. My pump and my colorsync both have their own wifi and both log directly into Pentair server.Pentair says an IntelliCenter account should now be accessible through the Pentair Pool/Home app after migration, using the IntelliCenter account credentials. Have you done a migration?This is how my app looks on my phone where it all connects directly to the pentair pool app. Are you using this same app or a different one? This plugin may just not work using that different system. When you login, 1) are you using this app, and 2) does it list all your items as primary items or does it list your intellicenter with other things under it? Edited Monday at 05:39 PM2 days by apostolakisl
Tuesday at 04:29 PM1 day Pentrair_beta is now posted to non-production store. Adds Intellicenter functionality.Pentair has two completely different api's that both reside on the same server/login structure, so regardless of whether you have intellicenter or just direct connect of pump/lights, this plugin, username/password setup works. The plugin self-discovers the correct api to use based on how your account in pentair was configured.
