September 8Sep 8 After mistakenly doing the beta upgrade and migrating pg3 nodes all seem to work except audio player. I gaet this message, Error loading node n011_0: Profiles loaded but nodedefs missingHow do I fix?ThanksAlso this message for avremote, Error loading node n001_controller: Profiles loaded but nodedefs missing Edited September 8Sep 8 by garybixler
September 8Sep 8 16 minutes ago, garybixler said:After mistakenly doing the beta upgrade and migrating pg3 nodes all seem to work except audio player. I gaet this message, Error loading node n011_0: Profiles loaded but nodedefs missingHow do I fix?ThanksAlso this message for avremote, Error loading node n001_controller: Profiles loaded but nodedefs missingThe plugin probably needs to be reinstalled. Go to the plugin store, and re-install in the same slot.
September 9Sep 9 Author I tried that again but with the same results. It shows connected but still getting the error.Update: all my node server have the same error except the ones still om PG3. Edited September 9Sep 9 by garybixler
September 9Sep 9 Author I was able to migrate the NSs back to PG3 with the exception of audio player. I deleted it from eisy-ui and tried to install it back in PG3 but PG3 will no longer install any node servers. If I install it in eisy-ui I keep getting the mentioned error.Additional info.According to UD Mobile the audio player keeps connecting and diconnecting. Edited September 9Sep 9 by garybixler
