September 24Sep 24 Couple of MINOR issues:The Protocol Submenu reported "No API installed" when I clicked on the Z-Wave until I rebooted the system. The rest showed up.The Protocol Submenus for each protocol should have the enable/disable switch in the same location for each. <-- MINOR!!!The Display setting for "Light" still uses yellow text on the white background to let you know that the system is rebooting. (VERY difficult to see...)The Insteon Protocol page "Show PLM Links Table" shows "No Records Found" while the System Busy orange banner is up at the bottom right. No link dump is returned.What I like that is now added:Node details like X-Ray, restore, etc.The configuration tab in the System Submenu has the same settings as the AC config page except the protocol switches (new sub menu)What I did NOT find:The AC has the Event Viewer - Level 3. Device communications events. (It would be nice to have a rolling log like the rest for this. I have a non reproducible error so I don't want to keep the AC log running waiting for the error to occur).This strikes me as REALLY close to the AC feature list...I may edit this post with more findings... NICE WORK ALL!!EDIT 1: The scene control options in the AC have been whacked and only show "Write Changes" without the ability to make edits there e.g. On or Off, etc.The eisy-ui seems to allow proper edits. I have lots of lights that come on at sunset and off late in the evening. The turn on event failed from the scheduled program, but running the "then" of the program worked from UDM. Will monitor this evening and see what happens...EDIT 2: OK, this is weird: I edited ONE program in eisy-ui to test and the AC now has all the scene options under "Your Devices"... SMH Edited September 25Sep 25 by JimTurner more info
