Yesterday at 07:06 PM1 day Is there a way have persistent storage for variables across IoX reboots or upgrades? I have some items that I track long term that get lost whenever IoX is upgraded or rebooted. For example I count each time the sump pump is turned on as way to gauge its life span. I also track power on hours on my HRV (Ventilator) as way to judge it's overall life as well as to know when I need to do maintenance on the ventilator. I can think of other possible uses of persistent storage as well. Does anyone know of a way to accomplish this? ThanksMike
Yesterday at 09:43 PM1 day Update the "Init" value of the variable every time you update the variable itself. This will set the value of the variable to the "Init" value across reboots.
8 hours ago8 hr Author 16 hours ago, Bumbershoot said:Update the "Init" value of the variable every time you update the variable itself. This will set the value of the variable to the "Init" value across reboots.This is a great idea. The only issue I can see is that it won't survive a Restore from backup but this is minor. I think I'll implement some programs that do this on a daily basis rather than every time a variable is updated.Mike
