upgrade fails in eisy ui
Have switched plugins from PG3 to eisy ui plugins beta. My version is 1.8.60 and when I try to upgrade to latest version in the eisy ui store, I get message below and upgrade fails.
There are no errors in the Yolink log - Maybe try to reboot the system or reinstall the nodes - there are other nodes with errors as well
OK.. Rebooted eisy and restarted the plugin. Still get the same error. Interestingly, all of the Yolink devices seem to be working fine. Should I delete the plugin and add back in plugins beta, or add back in PG3 , then migrate?
I saw there just was a new release of the UI - maybe try that before anything else
I would try to delete and reinstall - I believe they are really the same
Solved. Turns out that the plugin did not like updating via portal, but did update on local network.
