Odd -- Mac accesses eisy.ui fine but PC has issues
THis is odd but by no means an urgent issue. Two machines both using wired ethernet on same LAN, both using Chrome browser. Mac works fine with eisy.local and numerical ip address. On PC eisy.local login fails --gets to password screen then redirects to eisy.clocal:3000 and eisy refuses to connect (according to chrome). Can log in on PC using ip address but on the system upgrade screen only three packages are listed-- eisy-ui, IoX, and UDX. This is with staging repo-- 1.4.3_1, 6.1.2_10, 5.0.0_7, PG3x 3.4.26, and mosquitto 2.0.18 . Rebooting eisy and restarting Chrome did not affect this behavior.
CORRECTION -- The part about the PC only displaying 3 packages is only partially correct. If I zoom out using the Chrome scren % tool, both the pc and the mac show seven packages. I had thought earlier there was a mechanism for scrolling but there isn't currently, or at least not that I can find. So the only difference between the PC and the MAC is that the PC can't access via eisy.local. the page needs a scroll bar for the packages or a format that shows all at once.
the eisy.local access problem seems likely to be solved by clearing a cache in chrome or by creating an equivalence in c:\Windowas\System32\drivers\etc\Hosts -- but it's not really something that needs fixing.
Edited by stillwater
