October 14Oct 14 Guaranteed someone can educate me more on this because I think I am just missing something obvious, as I usually do. I have 4 Hue bulbs (can lights/downlights) in a screened-in porch. I have grouped them all into a scene to control them together, and I am able to dim them all together, etc. However, I am not quite sure how to adjust all the bulbs to a specific color (i.e., adjust the hue across all 4 in the scene) I am able to do this for each individual node and adjust the hue for each bulb individually, but I am not quite sure how to "expose" the hue setting in the UI to adjust them all together. What am I missing?
October 14Oct 14 Possible in eisy-ui > Scene. Might be in either Shared Commands or No Conflict Commands.
October 14Oct 14 If you go in eisy-ui and bring up the scene, you'll see the controller at the top and the list of responders below it. Now click on the ">" beside (on the left) of the controller and the responders expand to a list of editable boxes. Click on the light you want to configure, and change the Link Type from "Default" to "Command", and a Command box will appear. Pick the setting you want to edit, such as "Set RGB Color", and then you'll be able to set the value to what you want for each parameter. You can really edit everything.
October 14Oct 14 Author I found a bit of the issue, I had grouped the device nodes for each bulb I added and then when I add the grouped Node to a scene, it doesn show the hue.. If I add the specific Node with Hue it does show in eisy-ui but Not in UD MobileThat said, How does one expose the capability in UD Mobile? Edited October 14Oct 14 by MNTheatreGuy added a bit more context
October 15Oct 15 19 hours ago, MNTheatreGuy said:I found a bit of the issue, I had grouped the device nodes for each bulb I added and then when I add the grouped Node to a scene, it doesn show the hue.. If I add the specific Node with Hue it does show in eisy-ui but Not in UD MobileThat said, How does one expose the capability in UD Mobile?This capability does not exist in UD Mobile or the Admin Console only in eisy-ui. This is a new implementation, previously there were only static commands for scenes, no hue.
October 16Oct 16 Author On 10/15/2026 at 10:37 AM, Javi said:This capability does not exist in UD Mobile or the Admin Console only in eisy-ui. This is a new implementation, previously there were only static commands for scenes, no hue.Thanks, @Javi and now that I am reading more thoroughly (apologies, as I am just catching up on things), it seems as though the recommended approach going forward is to begin to utilize only EISY-UI, is that correct? UD Mobile has some interface things that I like quite a bit, such as color changes on status and the hue slider for a given bulb if you change it to a Hue bulb in the UD Mobile interface. No doubt the EISY UI will have some of these improvements over timeIf so, is there a way in EISY-UI to have one tile for multiple Hue lightbulbs whereby you can have 3 widgets/controls - 1)on/off bulb, 2)a slider for dimming and 3)a hue slider - Each one of those controls changes all 4 bulbs in unison?
October 16Oct 16 15 minutes ago, MNTheatreGuy said:Thanks, @Javi and now that I am reading more thoroughly (apologies, as I am just catching up on things), it seems as though the recommended approach going forward is to begin to utilize only EISY-UI, is that correct? UD Mobile has some interface things that I like quite a bit, such as color changes on status and the hue slider for a given bulb if you change it to a Hue bulb in the UD Mobile interface. No doubt the EISY UI will have some of these improvements over timeIf so, is there a way in EISY-UI to have one tile for multiple Hue lightbulbs whereby you can have 3 widgets/controls - 1)on/off bulb, 2)a slider for dimming and 3)a hue slider - Each one of those controls changes all 4 bulbs in unison?Yes, for some of the suggestions, not quite for hue slider with scenes. Play with favorites edits by adding multiple nodes. Most of the good from UD Mobile will be added to eisy-ui some of the legacy (synchronization !) will not .Favorites are scheduled to be moved into a grid so they work well on both Mobile and larger screens with options for multiple sizes.
October 16Oct 16 Author I have completely given up on the Hue settings for now and just hope to be able to have all 4 bulbs operate on and off and dimming. I have been messing around for hours now and I just have to be missing something because I cannot figure out how to dim all 4 bulbs with a single widget on a single tile. what I have tried: 1.) adding all 4 bulbs to a Group > which creates it own Node > then adding that Home Page. when I try to add a widget, I only get (Divider, Group Mean Status, Group Members, and scene command Buttons) See below 2.) Adding multiple nodes to the Tile. Then adding a widget, I select dimmer(good that it shows up this way), but then it wants to assign a command to that widget, which is specific to a single node(i.e one of the bulbs) Any suggestions on how to get a single widget to dim multiple lights?
October 16Oct 16 The Bad News:The issue is status, scenes do not have a status, a widget requires both a command and status, the status is used to set the current position of the slider. Scenes allow command can be set to all members, but combining status for all members presents issues. While this seems easy, what happens when on bulb is off and one is on, the mean is 50% but neither light is at 50%. So it is easy to set multiple devices to a value, difficult to make a slider or other widget.In UDM we use this mean status, and this is frequently debated and incorrect. At some point we may implement the same as UDM, but is likley months out at this point.The Good News.This will work with programs but is not instantaneous, will also work with setting hue for all Devices.Choose one device as the controller then track its status and set a variable.Then either create a scene with the other devices as "default" and set the scene to the variable OR set each device to the variable. Note my device is named '(Use Scene) Living Room Dimme' ..not a great name for this example.Default (Do not use native as ON percentage commands do not pass through native): OR Each Device:Now control the device selected as the controller, the program will update the others
October 31Oct 31 Author Works absolutely perfectly for dimming. Thank you @Javi for that.For Hue, I am not able to figure out how to adjust. I suspect it is because the value for Hue is not an integer and thus it does not get inserted into the variable. What am I missing?
November 1Nov 1 Also this may be a good test case for our custom tiles, to avoid the need setup programs/variables, and issue commands directly to the scene.Will look into on Monday for possible inclusion in next weeks webinar.
November 1Nov 1 Are your ue devices integrated via the hue hub? If so, I thought one could create a group in the hue app, which would show up as its own single node in the EISY. I am wondering aloud if this single node could be controlled as you wish.
November 6Nov 6 Author On 11/1/2026 at 10:12 AM, Javi said:Please show your programs and variablesthe value of Game Room Rame Room Color Hue-Sat - doesn't seem to get set into the variable. I wasnt able to get into the event to day due to technical difficulties, so apaologies if this was covered there.
November 7Nov 7 The IF condition is incorrect, it needs track when the Hue is changed not the ON/OFF status.
November 8Nov 8 Author true, kinda(meaning it is not the right time when I want to change hue, I was just trying to get the variable to accept the value of Hue) The IF clause does hit true, but the variable never gets the value from Hue (it stays zero) and the IF clause is returning true. The IF clause is always true because it is greater than or equal to, which will always return true.If I change to Hue great than(or lesss than) or equal to zero, it returns false. Edited November 8Nov 8 by MNTheatreGuy
November 9Nov 9 On 11/7/2026 at 7:39 PM, MNTheatreGuy said:true, kinda(meaning it is not the right time when I want to change hue, I was just trying to get the variable to accept the value of Hue) The IF clause does hit true, but the variable never gets the value from Hue (it stays zero) and the IF clause is returning true. The IF clause is always true because it is greater than or equal to, which will always return true.If I change to Hue great than(or lesss than) or equal to zero, it returns false.Located an issue with Hue and Saturation properties. The definitions do not match the Property update, specifically the UOMs do not match. My guess is this happens with other nodes also.Added issue for investigation, but we are currently a few weeks out: Issue: "Hue Bulb Profile/event mismatch"ID: /udi/issues/28
November 18Nov 18 Two fixes for Hue support.#1)Fixed Hue Node Def, so setting variables in Programs will now work. IoX 6.1.2_17, may require Update with interview from Node > Right Click > ConfigurationVerify the Hue Node has NodeDef > Properties > editor ZB_HUE. From Node > Right Click > Node Info"properties": [ { "id": "ST", "editor": "ZB_HUE", "name": "Hue" },e.g. #2Fixed Scene Commands for Commands with only named parameters:IoX 6.1.2_17Issuing Hue Commands from Scenes to all Hue Nodes will now work.
Thursday at 11:36 AM5 days After performing the Update with Interview on my Hue bulb, in IoX 6.1.2_17, the Primary Node now shows:Sub nodes appear OK, for example:Controls on this sub node function properly. How do I resolve the top level node Internal Server Error? Edited Thursday at 11:38 AM5 days by wrj0 Added sub node is functioning.
Thursday at 01:48 PM5 days Try interview on the Main Node. If that does not work try recreating profiles. "http://<controller-ip>/rest/profiles/move/zmatter/zigbee?recreate=true"
Thursday at 05:56 PM5 days Thanks, Javi.I did another Update with Interview on the Main Node (there's no plain Interview on the Main Node). And recreated the profiles using the url you provided, that returned: 200. Followed by a reboot. After each of these steps, the Main Node for the Hue bulb continues to show "Internal server error."
Friday at 12:16 AM4 days 12 hours ago, wrj0 said:FYI for others, this is now a know issue for Hue Branded bulbs, not for other Color bulbs. It is benign and can be ignored.Investigation ID: /udi/issues/33
