October 14Oct 14 Hi @bpwwer ,After I updated IoX to 6.2.1 Vue will not start correctly. The error is below. I deleted the plugin and reinstalled it, but the error remains.Update:I just saw another thread regarding the Boto3 file. I had to reflash my eisy prior to doing the upgrade. I just installed the dev packages from the AC but the error is still there.Thanks for any advice.2026-10-14 14:11:17.461 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: User=None 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjA6NDQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiJTaUQqTE5Sb3pkQiovVncqIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMjYiLCJpc3lWZXJzaW9uIjoiNi4xLjIiLCJlZGl0aW9uIjoiRnJlZSJ9 2026-10-14 14:11:17.462 MainThread udi_interface INFO __init__:<module>: Loading interface module 2026-10-14 14:11:17.509 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2026-10-14 14:11:18.018 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading node module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading custom module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading isy module 2026-10-14 14:11:18.239 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2026-10-14 14:11:18.240 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2026-10-14 14:11:18.240 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.4.7 Starting... 2026-10-14 14:11:18.241 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/vue.py", line 10, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/__init__.py", line 2, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/pyemvue.py", line 8, in <module> 2026-10-14 14:11:18.242 MainThread udi_interface ERROR udi_interface:write: import boto3 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: : 2026-10-14 14:11:18.243 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3' 2026-10-14 14:11:49.530 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: User=None 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:49.530 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026044_3 2026-10-14 14:11:49.531 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjA6NDQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiJTaUQqTE5Sb3pkQiovVncqIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjQuMjYiLCJpc3lWZXJzaW9uIjoiNi4xLjIiLCJlZGl0aW9uIjoiRnJlZSJ9 2026-10-14 14:11:49.531 MainThread udi_interface INFO __init__:<module>: Loading interface module 2026-10-14 14:11:49.577 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2026-10-14 14:11:50.084 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading node module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading custom module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading isy module 2026-10-14 14:11:50.306 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2026-10-14 14:11:50.307 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2026-10-14 14:11:50.307 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.4.7 Starting... 2026-10-14 14:11:50.308 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/vue.py", line 10, in <module> 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/__init__.py", line 2, in <module> 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2026-10-14 14:11:50.309 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026044_3/pyemvue/pyemvue.py", line 8, in <module> 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: import boto3 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: : 2026-10-14 14:11:50.310 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3' Edited October 20Oct 20 by tmorse305
October 17Oct 17 It's working fine on my eisy, but I'm on the staging branch so have more updates on mine than on the production or beta branches.I do see in release notes that UDI has been adding python packages so it may be that the current production branch doesn't have that package yet.
October 18Oct 18 Author Thanks Bob,I actually have 2 eisy's running and I compared the configurations of the machines. See attached. The Pelham machine has the Vue that will not run. It runs fine on the Clermont machine. I queried the Clermont machine (works)and couldn't find any indication that boto3 is installed or running.
October 18Oct 18 May be an installation problem. Can you download the log package for the one that's not working and PM it to me?
October 20Oct 20 Author Solution Final update and solution!I opened a ticket with UD. The boto3 file is included in the dev package but some of the items in that package must be compiled before use. Just downloading the dev packages was not enough. To get the needed file to be compiled I had to delete the plugin and reinstall it.I had to reflash my eisy because the IoX upgrade failed, then restore from backup. That's how i ended up with the plugin installed but no development packages Edited October 20Oct 20 by tmorse305
8 hours ago8 hr I am seeing the same issue - I migrated to the new eisy.ui and after that it failed. I did try reinstall, but it does not see to clear memory - My credential remain after I reinstall in same slot LOG2026-10-26 14:31:34.867 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': '413964', 'uuid': '00:21:b9:02:6f:52', 'profileNum': 8, 'address': '413964', 'name': 'VUE Tahoe Main Panel', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '413964', 'isPrimary': 1, 'enabled': 1, 'private': None, 'timeAdded': 1793050266685, 'timeModified': 1793050294859, 'dbVersion': 1} from Polyglot2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': '413964', 'uuid': '00:21:b9:02:6f:52', 'profileNum': 8, 'address': '413964', 'name': 'VUE Tahoe Main Panel', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '413964', 'isPrimary': 1, 'enabled': 1, 'private': None, 'timeAdded': 1793050266685, 'timeModified': 1793050294859, 'dbVersion': 1}2026-10-26 14:31:34.872 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message setController2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING setController2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS setController message {'success': True} from Polyglot2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_handleInput: connection status node/driver update2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: dev.channels is <class 'list'>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310cfab8290>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2170250>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22125d0>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22123d0>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212590>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212450>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212490>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212290>2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212390>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212410>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22122d0>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212310>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212350>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212150>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212250>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212190>2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: GID: 4139642026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Manufacturer: SXF2438A001A1C6920E302A42026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Model: WAT0012026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Firmware: None2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Name: VUE Tahoe Main Panel2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Found channel: 1 - Heat Tape (None) Edited 8 hours ago8 hr by Panda88
