October 17Oct 17 Was anyone able to migrate the Ecobee plugin from PG3 to eisy-ui? I have migrated all the other plugins but this one is giving me some issues; I had to move it back to PG3Here are some screenshots of what I see before and after the migration:1. In the program it cannot set the 'Heat Setpoint'after migrationOn the home page I have a tile for the main thermostat and here is what I see when selecting the propertiesafter migration
October 18Oct 18 @bmercier, @Javi Is this an issue with plugin configuration, the migration or eisy-ui?
October 19Oct 19 17 hours ago, Jimbo.Automates said:@bmercier, @Javi Is this an issue with plugin configuration, the migration or eisy-ui?@Jimbo.Automates None of those. That would be IoX. Or possibly the plugin's profile files, but given that it works in PG3, it should also work in eisy-ui the same way.@Cosmin Munteanu Could you please open a ticket referencing this thread, and do this.Find your ecobee node address.When the plugin is running in PG3, capture the output of this url:/rest/nodes/<ecobee node>/profilesThen migrate to eisy-ui, check that you have the problem, then capture this again:/rest/nodes/<ecobee node>/profilesFrom the screen shot above, it looks like property names would be missing when running in eisy-ui.
October 19Oct 19 Author 33 minutes ago, bmercier said:From the screen shot above, it looks like property names would be missing when running in eisy-ui.@bmercier It looks that this is what's happening. I opened the ticket and attached the outputs. Here is what they look like before and after migration:BeforeAfter
