Thursday at 07:18 PM1 day I find the background (black) and the general color scheme of eisy-ui to be almost unworkable. In my case, I have lighting, sunlight, and dust problems on the screen which make many of the items unreadable... in addition some of the text are of colors that don't work well on a black background.Is there a way to change the color scheme?
Thursday at 07:26 PM1 day Under eisy-ui -->settings --> display you get a choose of light (black letters on white background) or the current white text on back
Thursday at 07:45 PM1 day Yes, though some of us have color monitors 😆It would be nice to pick a soothing background color.
Thursday at 09:46 PM1 day Author 2 hours ago, EricBarish said:Under eisy-ui -->settings --> display you get a choose of light (black letters on white background) or the current white text on backAnd where are the settings? I assume that might be a solution, but I could never find the settings although they may be in that black mess.
Thursday at 10:21 PM1 day For @bmarsh ---- @EricBarish told you where in the section you quotedAccess the menu by clicking on the three bars at the top left of eisy-ui. Settings is the second option from the bottom. Display is the third tab (the rightmost one at the top of the screen). Presumably you want to chose Light (bottom radio button) or System Default (top radio button).
20 hours ago20 hr If you do not see a tab under Settings called Display, then you need to upgrade packages because it was a recent addition.
16 hours ago16 hr It would be really nice if you could have alternating lines of slightly darker/lighter so you can follow across the page more easily. Or maybe very faint lined pages, like an excel spreadsheet, but not quite so obvious.
