Virtual showing percent
Hi,
Just wondering if a virtual device could be added showing a percent value for humidity etc.
Thanks.
Please disregard. Ill try using a dimmer switch.
Gary
Edited by garybixler
I have been trying the virtual dimmer but have a couple of questions. First my conf is {"type": "dimmer", "name": "Light Level"}. I noticed that you can't add special characters like % to the name. I am updating the status from a variable and can't seem to get the status to show 0. The lowest it will go is 5,
Thanks for any assistance.
Gary
@garybixler ,
Hi Gary, you are right special characters are not allowed as node names in any UD node. The 5 is being inserted when the node is on and you try to set the dimmer to zero. You can set 1,2,3,4. If you want zero then turn the node off. This is a bit of a carry over of using this as a dimmer node. So you cannot be on and zero at the same time. Hope this helps.
@sjenkins
Hi,
I tried setting different things at the node but every time it gets an update from the variable that is 0 it defaults to 5. Maybe I missed something that you were saying. I did see the range in the virtual dimmer definition showing a range of 1-100. Is there something need in the definition?
Gary
@sjenkins Hi,
I have discovered that the virtual dimmer will not accept the status being set to 0. It requires 1 and above otherwise it will default to 5. Maybe that could be addressed in the Virtual plugin.
Thanks.
Gary
@garybixler ,
Maybe I wasn’t clear in my comment above; that behaviour is on purpose. Zero and ON do not make sense at the same time. So as someone hits dim again and again there are two choices when you approach zero. Either turn the device off and enter zero or “bounce” off zero to a minimum number, in this case 5 was chosen. You can be ON and enter or Brighten/Dim from 1-100. This minimum ON was meant for using this virtual as a generic dimmer. If you want zero you switch the device OFF.
