Monday at 04:21 PM4 days Almost always, setting a number of seconds or minutes to 'Wait" does not update in the program. It simply shows "Wait" in the program. I keep trying, sometimes it will save, often not.Same with Schedules. For example, setting a time before or after sunset does not save. It will save as Sunset or Sunrise but offsets will not save in the program.I rebooted the eisy but problem persists.Edit: I use Firefox. If I open in Chrome they seem to save okay. So Firefox issue? I don't like using Google. Edited Monday at 04:35 PM4 days by nowandthen
Monday at 04:59 PM4 days The Firefox-only behavior you're describing sounds like a client-side save issue rather than the eisy itself, since Chrome writes the values fine and a reboot didn't change anything. Have you tested a private Firefox window with extensions disabled? Privacy add-ons or strict tracking protection can interfere with how the UI submits and refreshes form data. Also worth clearing the eisy-ui site data/cache in Firefox and trying a hard reload. If a clean profile saves the offsets reliably, you've narrowed it to your Firefox settings rather than the device.
