November 3Nov 3 @Javi None of my Insteon Plug in Dimmer Modules (2457D2) expose any configurable options in EISY-UI (or in AC). The module supports the 4 options typical of most Insteon devices (i.e. Program Lock, Transmit LED, No LED and Beep) as well as Resume Dim and Load Sense On/Off. There is no "Options" button on the Configuration menu in EISY-UI, nor is there an Options button on the node screen in AC. Most of my modules show up as "(B2457D2) LampLinc BiPhy v.43" although a couple are v.41. The behavior is the same for both versions.Is this by design, or is there some corruption in my installation?Thanks,Dave
November 3Nov 3 Author Yes, the node info is the same in mine: But if you right click the node and choose Configuration, there is no "Options" option in the configuration screen:Dave
November 3Nov 3 I guess I've never noticed (or used) these options. I have 5 lamplincs and I'm seeing the same thing you are, with no Options button.
November 3Nov 3 If not in the admin console then this would be a feature request/investigation.Without precedent I'm not sure of the reason it was not implemented It could be config was tested and did not work, caused other issues, or was simply missed.
Monday at 01:14 AM5 days Definitely seems like some options are missing. I went through the process of setting up an old Lamplinc this evening thinking it has a "resume dim" function, but that doesn't appear to be exposed in the eisy-ui user interface. @Javi Is this something that could/would be queued up for future implementation as a feature request?
Monday at 10:36 AM5 days Author @dwengrovitz In the meantime, according to the old version (2014) of the 2457D2 Insteon manual, you can enable and disable Resume Dim using the Set button:Long Press 4x > Tap 3x > Long Press 1xThe newer version of the manual, dated 2017, omitted this page, so your mileage may vary.Dave
Monday at 04:13 PM4 days 14 hours ago, dwengrovitz said:Definitely seems like some options are missing. I went through the process of setting up an old Lamplinc this evening thinking it has a "resume dim" function, but that doesn't appear to be exposed in the eisy-ui user interface.@Javi Is this something that could/would be queued up for future implementation as a feature request?Added issue. ID: /udi/issues/34We are likely a few months out on Insteon feat implementations that did not previously exist in Admin Console.
