Ratgdo 4.0.8 discovery fails — firmware endpoint ret
@Goose66 — I’m experiencing the same discovery issue.
• Eisy-UI / IoX 6.1.2
• ratgdo plugin Standard 4.0.8
• Board: v32board_secplus2
• Firmware: 32.0, ESPHome 2026.7.0
The ratgdo works in Home Assistant, and its web page loads normally.
Automatic discovery finds nothing. I added this custom parameter:
gdodevice = 192.168.1.172;ratgdo32-46b680
The plugin accepts it, but discovery fails with:
404 Client Error: Not Found for url: http://192.168.1.172/text_sensor/firmware_version
Is there a plugin update or configuration workaround for this firmware? I want to retain the working Home Assistant setup.
There is a lot of discussion here
Bottom line, you have to downgrade the firmware on the Ratgdo device for the plugin to work from github
10 hours ago, drprm1 said:
Did that and working as expected
OK, I took the ratgdo plunge, and got it working - sort of:
  1. I used the config tool located at https://ratgdo.github.io/esphome-ratgdo/
  2. to start the upload process.
  3. Once completed and WiFi enabled, you can "visit the device" from the popup (which is basically an IP call in the browser)
  4. That page shows the ability to upload the new "OTA" bin file that I linked above.
  5. Wired up the device (it needs attachment to the GDO to "discover" the device)
  6. I added the gdodevice / 192.168.x.x;ratgdo32-xxxxxx to the config and discover worked! (xxxxx will be your device code on the ratgdo.local page or your local IP address page assigned by your router
That's the good news.
The bad news, is that the device will close the door, then immediately reopen. Not sure why, but I will continue the investigation / configuration troubleshooting tomorrow - unless anybody has ideas for me to look. FWIW, I also bought the ratgdo encoder that is supposed to show door position...
~jimt
