Looking to upgrade from an ISY99i to the new eisy r2
I am looking for an overview of what the upgrade process would be like to convert from using an older ISY99i to the new eisy r2.
On 11/14/2026 at 10:27 AM, Techman said:
Take a look at this link for a migration overview
Eisy:User Guide - Universal Devices, Inc. Wiki
The documentation in the link refers to the ISY994 - would it also apply to the ISY994i? Just want to be sure...
Edited by CCataldo
Changed "ISY99i" to ISY994i"
The migration to the eisy requires that your existing firmware must be 4.x or 5.x. If your running 3.x firmware then the migraion isn't possible due to the incompatibility. You'll probably have to build the new system from scratch
You should also use a USB PLM with the eisy as it doesn't require a conversion cable
