Yesterday at 03:04 PM1 day I added logging of programs to IoX logger. No more frustrating only getting to see the last run of a program when debugging a misbehavior. You can see all the runs and whether it ran then/else. It is all handled through the html interface at port 8765 as before. It will log all program activity when enabled for a selectable period of time. You can search the log within the html window, or you can download a csv file and use your preferred program to organize and search it. I also added authentication to open the html control page. To enable the logging, you will need to enter your LOCAL iox username (admin) and password. Not the portal credentials.
Yesterday at 05:50 PM1 day @apostolakisl I got hung up accessing the Web Interface.http://192.168.1.3:8765/ results in the following in Chrome:
Yesterday at 05:55 PM1 day Author 3 minutes ago, Ross said:@apostolakisl I got hung up accessing the Web Interface.http://192.168.1.3:8765/ results in the following in Chrome:Are you running 1.1.0 or 1.1.1. I had that issue as well and thought I figured it out and fixed it with 1.1.1. I'm hoping you are 1.1.0 cause if not I have to look at that some more. The plugin was running and logging, but the html wasn't working. Currently I am not having issues running 1.1.1.EDIT: I see the issue, https:// not http:// Edited yesterday at 05:58 PM1 day by apostolakisl
22 hours ago22 hr Author 25 minutes ago, Ross said:@apostolakisl Unfortunately, 1.1.1.did you use https:// your screen shot shows http://
