My experience migrating PG3x to Plugins
For anyone interested, on Sunday I migrated all of my Node servers from PG3 to plugins on the eISY.Quite frankly, I was a bit nervous about migrating them all at one time. As I have 25 plugins so far I decided to migrate one at a time. I took my time and did the process methodically, selecting the ones that I did not think would be any issue at all and saved the ones that tie into lots of programs and such to be done afterwards.
Migration was piece of cake. No major hiccups, no major dilemmas. Most everything worked as it did before. The only minor issue that I saw was with two plugins, Vue and WebControl832, which is one that I developed. The minor issue with both of those was that if I had any of those included in scenes, when they migrated over, they were no longer in scenes or groups as it's now called. Thankfully, I only had a handful of groups to recreate. Really quite easy, to be honest.
I was inclined to believe that maybe I missed something or misconfigured something when making the WebControl832 plugin to where it caused the Grouping issue during migration, but since Vue seemingly had the same issue, I'm now not quite sure.
All in all, everything went extremely well. Thanks to Michel and his team. Everything for me really went without a hitch. Thank you all!
I get "Error getting PG3 plugin config: Request failed with status code 503" message when I try to migrate. Any thoughts on getting around this?
503 means service unavailable. So some service that the migration utility is looking for isn't running or doesn't exist. I would start by trying a full reboot of eisy. Is this with any plugin you are trying to migrate or all of them?
@TJF1960 I have not had 100% success with plugin migration. For example, eisyir does not survive the migration. Most problems center around permissions issues. I changed some code in eisyir on my system to fix it, but as it is, I can't update the plugin should one become available without losing my fix unless the author also fixes that same issue. My fix is not a generic fix though, it is specific to my system, so a generic fix of the plugin would need to be done differently. It is possible if I deleted it and isntalled from scratch this wouldn't be an issue.
