Wednesday at 06:41 PM2 days I have two Insteon on/off switches that control my outdoor flood lights. They've been in service for over a decade. Last night my wife told me one of them was not working. (We seldom using the flood lights so I don't know how long ago this issue may have started.)So I spent over an hour this morning trying to diagnose what was going on. Removing and relinking the switches, rebooting the EISY, and so on. In both EISY-UI and Admin Console. Here's what I eventually figured out:I had removed one of the switches from EISY but forgot to remove the other one. When I tried to relink that switch, two different events happened:EISY-UI 1.4.8: The linking process just does nothing. No messages that the device already existed. Just ends the process and goes back to the previous screen.ADMIN CONSOLE: The linking process caused 4 or 5 dialog boxes to open, overlaying each other. I had to work to get them closed. One of them was the "linking" dialog (which I had not initiated), so apparently the EISY thought it was still trying to link my device. Two dialogs mentioned a package upgrade was available (even though I'm on the current release). I don't know why those appeared. Finally I found a box saying the switch I was trying to add already exists. Ah ha! I had forgotten to delete one of the switches out of a folder I had stashed it in long ago.I removed the switch and then I was able to relink it OK using EISY-UI.So I seem to have stumbled upon a bug? EISY-UI doesn't tell you an Insteon device already exists. It just sits there in linking mode and does nothing. Admin Console loses its mind (sort of), but at least it told me the device already existed.Please revise EISY-UI to report when a device already exists.
Wednesday at 07:47 PM2 days Author Automatic. Protocols > Insteon > Start linking. It never acknowledges the switch when I press the Set button and it double-beeps.
Thursday at 04:36 AM1 day Author As I mentioned, the Admin Console recognized the link attempt and told me the device already existed. But EISY-UI seems to just give up with no notification.Thanks.
8 hours ago8 hr Fix now in pipeline 1-2 releases out.Fix ID: /eisy-ui/pull/181- Fixed insteon rename after linking (address conversion).- Show previously linked devices if a user presses set button on device that already exists in eisy.
