7 hours ago7 hr Still getting use to new UI. Improving. If I read the documenation correctly, I should be able to access the eisy device using either eisy.local vs actual IP address. I am able to successfully use the actual IP address, but I get a series of error messages when trying eisy.local (server IP address could not be found). Did I miss something again when setting up everything?Thanks
6 hours ago6 hr Both should work. I personally use the IP address because it skips any problem with local name resolution.
6 hours ago6 hr @j.rieff eisy.local works using mDNS, In some networks, it's possible that eisy.local will not work. Your router may have security settings that prevents this.If you have different subnets, with your eisy in one subnet, and your computer in a different subnet, that may not work.
3 hours ago3 hr 2 hours ago, tazman said:@bmercier is there a reason why eisy does not seem to resolve the .local addresses?Usually due to mDNS filtering of some sort.. Network config and equipt are factors.One forum member had a corrupt DNS cache causing eisy.local issues, cleared using DNS tools in his Firefox browser. Same issue on my brother's Mac but cleared using Safari developer tools. Once cleared they were fine. Edited 3 hours ago3 hr by mmb
3 hours ago3 hr 7 minutes ago, mmb said:Usually due to mDNS filtering of some sort.. Network config and equipt are factors.Or more simply, one forum member had a corrupt DNS cache on his Firefox browser that was causing eisy.local problems. Same issue on my brother's Mac using Safari. Once cleared they were fine.I think you might not understand what I was asking, eisy.local works on my network and I use it for other network use but I can not use the .local witin the eisy box. Unfortunately I have to deal with a network that does not have the ability to reserve ip addresses.
2 hours ago2 hr 29 minutes ago, tazman said:I think you might not understand what I was asking, eisy.local works on my network and I use it for other network use but I can not use the .local witin the eisy box. Unfortunately I have to deal with a network that does not have the ability to reserve ip addresses.One workaround could be to assign a fixed ip address to the eisy. It needs to be left as dhcp, but you can assign it an alias address that is fixed. You could also put it's own name in it's /etc/hosts file with it's ip address.See here about setting an alias:https://forum.universal-devices.com/topic/47335-eisy-connectivity-due-to-dhcp/#comment-408818
