ISY ramp rate [applied locally] not working
I'm using my ISY99i to set the on level and ramp rates on all my light switches to help increase bulb life. When I go into the ISY and set the on level to 80% then manually turn on my switchlinc the light correctly turns on at 80%. but when i set the ramp rate to say 10 seconds or any setting actually and then manually turn the light on it immediatley turns on at 80%.. i would expect it to ramp up slowly and take 10 seconds to get to 80%.. am i doing something wrong?? or is this possibly a known issue? ive searched the forum but did not find anything that seemed to fit my situation.. i very well could of missed it though..
thanks for your help
It is a SwitchLinc and not an ICON switch. Also what is the revision level?
so looking at my ISY admin console my dining room light is a switchlinc dimmer V.27 the smarthome model # is (2476D)
hmm as i was typing this i knew that i had some switchlinc's that were version v.35 so I set the ramp rate on those and it worked!!
soo i guess there is a problem with the V.27???? is there a fix for these?
thanks for the info LeeG!!
The older SwitchLincs and LampLincs have to be power cycled before the new settings take effect. Pull the set button for a few seconds.
Rand
That worked like a charm. Thanks guys!! this forum is the best
