Device Name In Router Table?
When I look at the table of devices attached to my router, there is a name associated with every IP address except the ISY-99i. I don't see any way in the configuration to set a name for this device. Of course, this isn't a big deal, but I'd like to give it a name.
Hello johnmsch,
That's quite odd. You should see:
ISY99-HOME-AUTO
Can you tell me what's your ISY's firmware version?
I was wondering about this too. On both 2.7.15 and 2.8.3 I have not seen the hostname show up on my linksys router nor on the new setup I just did for a friend on his Dlink router.
I have a D-Link DI-604.
FW 2.8.2
My router table says ISY99-HOME-AUTO.
If I power cycled the router it then said unknown.
If I did a power cycle of the ISY99i, Router, Computer and DSL Interface. It again said ISY99-HOME-AUTO. :wink:
So if the router causes the connection to be reestablished it does not request the hostname, but when the ISY reestablishes the connection then it does. I have to say other devices on the network sometimes show hostnames and sometimes do not for my setup. Like right now I have 8 things connected to my router and none of them show a hostname except for my iPhone.
Hi Brian,
DHCP Offer-name is only sent in the following conditions:
1. ISY is rebooted and it's trying to get a new lease
2. ISY is trying to renew the lease
In the case where ISY has a lease and the router is rebooted, and if ISY does not know that the router has been rebooted, then it will not try to renew/rebind and thus the unknown.
Thanks for the excellent support as always.
Hi Brian,
I'm on 2.7.15. The post above explains what is happening. Thanks!!!!!
