December 5, 200718 yr Reverted back to 2.4 and can add devices again. Linking Most of the time was unable to link with 2.4, never worked with 2.5. I may have a noisy system - 60 devices, no filterlincs and several low voltage devices. Turned off low voltage devices where possible and still no linking. Switched controlled low voltage was switched off - no change in behavior under 2.5
December 5, 200718 yr RichGer, 2.5's driver is no different than 2.4 and I am quite confident the problems are noise related. I strongly advise going back to 2.5. With kind regards, Michel reverted back to 2.4 and can add devices again. Most of the time was unable to link wit h 2.4, never works with 2.5. I may have a noisy system - 60 devices, no filterlincs and several low voltage devices. Turned off lowvoltage devices where possible and still no linking. Switched controlled low voltage I switched off - no change n behavior inder 2.5
December 5, 200718 yr Author Will try adding devices under 2.5 again BTW remote "upgrading" back to 2.4 worked ! Smile Despite 10+ tries remote upgrade from 2.4 to 2.5 did not work Was upgrade function within 2.5 improved?
December 5, 200718 yr Hi RichGer, I just upgraded your system from 2.5 to 2.5 remotely. I 100% confident that you must've had some firewall issues since none of that function has been changed for at least 6 months. With kind regards, Michel Will try adding devices under 2.5 again BTW remote "upgrading" back to 2.4 worked ! Smile Despite 10+ tries remote upgrade from 2.4 to 2.5 did not work Was upgrade function within 2.5 improved?
