November 19, 201015 yr I have 4 keypads in the house and anytime I push all of on any off them it turns all the lights off but if any keypad buttons are one(the light behind the button) it doesn't turn it off. I tried adding those keypad button to the all of scene but to do that I need to change the keypad from a controller to a responder. If I do this the keypad will no longer work as a controller right? Any way to fix this issue.
November 19, 201015 yr I have 4 keypads in the house and anytime I push all of on any off them it turns all the lights off but if any keypad buttons are one(the light behind the button) it doesn't turn it off. I have read that sentence (and the whole post) several times, and remain uncertain as to it's meaning or your problem. Is there any chance you can re-phrase and elaborate? I apologize for being a little slow.
November 19, 201015 yr Author I have four keypads. Lets call the keypad A-B-C-D. Lets say i turn on scene A on keypad A it also turns on the light inside button A on keypad A. If i go to any keypad A-B-C or D and push the all of button it will turn off all the lights in the house but the light that that's inside button A on keypad A stays on. This creates to problems. 1 once all the lights are off I still have keypad buttons that are glowing. 2 the next morning when I go to turn on a scene that's off but the keypad button is still on I have to push the button twice. Once turns of the button itself and does noting to the lights and the second time it turns on the button and the scene. Hope this clears it up for you.
November 19, 201015 yr I understand your problem, and it is frustrating. The issue is that the keypad button is a controller in the scene (Scene A) that controls the light, and therefore the keypad button status light reflects the status of that scene, not the status of the light. My solution has been to add the keypad buttons as responders to the All Lights scene. A keypad button can be a controller in one scene (Scene A) and a responder in other scenes, such as the All Lights scene. With 4 keypads and presumeably six or seven buttons each, that is a lot of responders in one scene. It should not be a problem, though.
November 19, 201015 yr Author I wasn't aware that the same button could be configured as controller in one seen and responder in another. I'll try that tonight and if it works it's going to be a lot of programing considering I have 4 keypad with eight buttons each but an easy fix. Thank You
November 20, 201015 yr I wasn't aware that the same button could be configured as controller in one seen and responder in another. I'll try that tonight and if it works it's going to be a lot of programing considering I have 4 keypad with eight buttons each but an easy fix. Do you not have an ISY-99? This would alleviate much of the burden of programming. Yes, it sounds as if you need to make Keypad A button A a responder in the other scenes.
November 20, 201015 yr Author Yes I do have a ISY 99.Just wasn't aware that one device could be configured as a controller in one scene and responder in another scene.
November 20, 201015 yr Yes I do have a ISY 99 it's going to be a lot of programing It just surprised me how you described this as a lot of programming. I apologize for my confusion.
November 21, 201015 yr Hi raptor, Each controller device can be a controller in one and only one scene but responder in up to 254 scenes. With kind regards, Michel
