JJ Posted December 11, 2010 Share Posted December 11, 2010 I have recently added the ISY to my system and Insteon works better than ever. I have a few programs set up from the ISY to turn on some of my x10 devices and that works fine. I use to have a couple of x10 devises that turned on when a door opens but they no longer work. I also had one of the F buttons to toggle a x10 switch that no longer works. I do not have the x10 module. Will the ELK control X10 through the ISY? If so what do I need to change? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 12, 2010 Share Posted December 12, 2010 Hello JJ, If you would like ELK to directly control X10 nodes through ISY, then you would need the X10 module. Does your ELK still have a PLC/PLM connected to it? If so, you really should not waste money on the X10 module. Instead, you should have programs that listen to X10 signals that ELK sends out. With kind regards, Michel Link to comment Share on other sites More sharing options...
