Not able to see E-Mail settings
Hi, it seems that all my E-Mail has been "Migrated" and I do not know how to get them so that I am able to edit any of them.
Does anyone have any ideas of how to get them back?
That's no problem.
Do I need to rebuild the e-mails or are there some other solution?
I just installed my ISY 99i last night and I'm having the same issue.
Firmware is 2.7.15
Address is the one provided with my instructions: http://www.universal-devices.com/99i
I just opened up my console using http://www.universal-devices/99i/2.8.10 Is that the correct thing to do? Things seem (so far) fixed this way.
Update:
Got it to work. Updated firmware and was able to set up notification and successfully tested a text notification.
Is there a way to test an actual custom notification?
Hi Avonlea22,
Glad to read you updated the ISY.
AFAIK the only way to test the custom notification is to use it in a program and run the program. Right-click the program and Run (Then).
Rand
Firmware is 2.7.15
Update:
