LED Brightness for KeyLincs
KeyLincs
using 2.7.15
This does not seem well described, or I've missed it. A couple questions ...
1) What is the "default" initial setting for the LED ON and OFF (background) levels? I understand that ON can vary 0 to 15, and the OFF from 0 to 7.
2) When you send an ISY program command for LED brightness, it has you select a specific keylinc button, I presume that that will still affect each of the device's buttons equally, that is only on preset brightness?
* Orest
I once had a keypad linc led brightness adjust from a program and it seriously scrambled stuff. I ended up having to remove the switch from ISY, factory reset it, and put it back to ISY.
I don't know why this happened but I will never use programs to change the led brightness again.
That was bad juju.
My wife acts likes she has "transparent eyelids", and insists on the LEDs being turned off at night in the bedroom. Leaving them that way during the day would make the switches largely useless, so I'm in a bit of bind.
I've left my sunrise routine to switch to 12 ON/1 OFF, and at night it switches to 1 ON/0 OFF. I'll keep an eye out.
* Orest
Please do keep us updated, as I am in the same boat. :D
So far, working just fine, and wife is happy. (job one)
These are brand new KL, so they would be latest firmware, FWIW.
* Orest
  • 1 year later...
So has anyone ever found out what the default settings for Off/On levels? I've played with the settings on one keypad and I would like to put it back to default to match other keypads without having to delete and reprogram. Thanks
