Stop and Disable for Programs; Folder Enabled/Disable
mvprj84
Was just thinking today - From tests I've run I don't believe disabling a program will also stop it if it's in the middle of running (e.g. on the wait command), and so I often issue a stop command before disabling programs that use the wait command. It would clean up my code a little bit if you guys offered a "stop and disable" option in the drop-down menu of available actions for programs.
One other thing that could be useful is the ability to enable/disable programs in an entire folder.
Those are the things that are apparent to me (aside from variables) that could clean up some of my code.
@Michel - Ahh, I know what I was thinking. I have some programs that I run by enabling them to be triggered by the "if" section, and then I also run them by calling the "then" statement directly at times. I noticed that if a program is disabled and you run the "then" section that sending the disable command doesn't do anything since the program is already disabled. I guess I expected it to be stopped in that situation as well, but the ISY is probably checking the status (enabled/disabled) of the program before setting it so that it's not unnecessarily disabling it again.
@apostolakisl - that is a clever workaround, and I think I have a few other ways that may actually be helpful. Thanks!
mvprj84,
Good observation about a disabled program in the midst of running it's "then" doesn't get terminated by sending a "disable" command to it.
I suppose that means that if you wanted to interupt a running "then" on a disabled program you would need to send an "enable" followed by "disable".
Clearly this is knowledge useful to only the most detailed of programmers, but potentially useful.
There is a Stop Program command.
Only when programs are in folders will disabling the folder stop the program.
Rand
mvprj84,
True, and in my code I was using the stop command in conjunction with disable commands to try get around this. I was just saying it would make things a little cleaner for me if stop/disable were consistently combined into one command.
      37.4k
      374.5k
