Posted January 19, 201114 yr I cannot get the 2477DH to program into the isy 99i comes up with high water mark massage and failed to add link
January 19, 201114 yr Hello fkoplik, The problem is communications. Please do the following: 1. Factory reset your switch 2. Go to Link Management | Start Linking 3. Press and hold the set button on your switch With kind regards, Michel
January 23, 201114 yr Author This is the new duel band 1000w sw. Smarthome said its not supported in isy yet.
January 23, 201114 yr Hello fkoplik, You should still be able to add this device ... the problems you are having has A LOT to do with the fact that ISY cannot communicate with your device. We added support for 2477DH in 2.8.11 which should be out shortly. With kind regards, Michel
