January 26, 201115 yr I tried both links below from my Laptop (different AV) and was able to successfully log-on and see the manual upgrade option. Obviously something on my other machine is causing an issue. Thanks to all for the responses & suggestions. http://www.universal-devices.com/99i/2.8.10/ or http://www.universal-devices.com/99i/2.8.10/admin.jnlp
January 26, 201115 yr For those that do not show 2.8.10 after update, after clearing the Java cache, did you invoke the 2.8.11 Admin Console from the UDI web site to do the actual manual update? i've been updated my ISY the same way I have always done per the instructions, which the version reporting problem started occurring with 2.8.10 betas. 1. backup system 2. manually update 3. exit all browsers and download managers 4. open java control panel to clear cache 5. clear browser cache 6. launch browser and enter url http://192.168.xx.xx/admin I have tried to perform upgrades from safari on a mac successfully in the past, but following the same procedure when i launch the admin console it hangs or never opens the credentials dialog and had to kill the safari process. only upon a second launch of safari of the admin console does the creds dialog get displayed, but then some of the isy pages are not displayed properly. this seemed to start happening with 2.8.10 betas. thus i have resorted to only performing updates via my W7 64-bit client. I am starting to wonder if there is a compatibility problem with 64-bit OSs running 32-bit java, and the ISY update process. FYI, I bricked two Elk M1 Golds trying to perform firmware updates using the ElkRP application running on my W7 64-bit client. I have received reports from others about other problems using the Elk RP application on W7 64-bit as well. I've given up making Elk firmware updates until i create a windows xp VM for such tasks.
January 26, 201115 yr The steps you listed are different from the steps UDI published at the beginning of this topic for installing 2.8.11. Have you tried doing an install following the steps UDI published?
January 26, 201115 yr Everything went great but now i am having problems of errors coming up saying cannot communicate with motion sensor. with the console open i can walk around the house go back to the computers and have a error for each ms on the screen that cannot communicate. Never had this before. Any Ideas? Thanks Jay
January 26, 201115 yr Jay Do you have small green icons to the left of the motion sensor node entries in the My Lighting tree? It sounds like there are pending updates to the motion sensors which cannot be completed until they are put into linking mode and a Write Updates to Device is performed. Lee
January 26, 201115 yr nope thats what wierd the notices started after the upgrade. i restored 1 of them last night and this morning when i walked by it gave me the message
January 26, 201115 yr If you can run Tools | Diagnostics | Event Viewer and select Device Communications Events. Post the event output after walking past an MS. Perhaps by looking at the commands executed we can tell what is happening.
January 26, 201115 yr Heres the event viewer is there a way to get this to sort when saved i open it up and everything is just together and it takes forever to go thru and pick the day and hit enter to make everything go line by line. Wed 01/26/2011 03:54:47 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 03:54:47 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 03:54:47 PM : [ 14 1B 2E 1] DON 1 Wed 01/26/2011 03:54:48 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 03:54:48 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 03:54:48 PM : Duplicate: ignored Wed 01/26/2011 03:54:48 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 03:54:48 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 03:54:48 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 03:54:48 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 03:54:48 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 42 11 01 LTONRR (01) Wed 01/26/2011 03:54:48 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=2, Hops Left=0 Wed 01/26/2011 03:54:48 PM : Duplicate: ignored Wed 01/26/2011 03:54:48 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 42 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 03:54:48 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=2, Hops Left=0 Wed 01/26/2011 04:04:47 PM : [ Time] 16:04:49 3(0) Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 04:06:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 04:06:03 PM : [ 14 1B 2E 1] DON 1 Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C3 11 01 LTONRR (01) Wed 01/26/2011 04:06:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=0 Wed 01/26/2011 04:06:03 PM : Duplicate: ignored Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C3 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 04:06:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=0 Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 04:06:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 04:06:03 PM : Duplicate: ignored Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 04:06:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 04:06:03 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 04:06:03 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=1, Hops Left=0
January 26, 201115 yr I had cleared the event viewer and was checking email and the error came up again so i saved and pasted here. sorry for so much but it ran the time alot and don't know why. the 14.1b.2e is the ms which is not linked to anything it runs a program after 10pm to sunrise Wed 01/26/2011 05:04:38 PM : [ 14 1B 2E 1] DON 1 Wed 01/26/2011 05:04:38 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 05:04:38 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:04:38 PM : Duplicate: ignored Wed 01/26/2011 05:04:38 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 05:04:38 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:04:38 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 05:04:38 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:04:54 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C3 11 01 LTONRR (01) Wed 01/26/2011 05:04:54 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=0 Wed 01/26/2011 05:04:54 PM : [ 14 1B 2E 1] DON 1 Wed 01/26/2011 05:04:54 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 05:04:54 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:04:54 PM : Duplicate: ignored Wed 01/26/2011 05:04:54 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 05:04:54 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:04:54 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 05:04:54 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:05:03 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 05:05:03 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:05:03 PM : [ 14 1B 2E 1] DON 1 Wed 01/26/2011 05:05:04 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01) Wed 01/26/2011 05:05:04 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:05:04 PM : Duplicate: ignored Wed 01/26/2011 05:05:04 PM : [iNST-SRX ] 02 50 14.1B.2E 00.00.01 C7 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 05:05:04 PM : [standard-Group][14.1B.2E-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:05:04 PM : [iNST-SRX ] 02 50 14.1B.2E 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 05:05:04 PM : [standard-Cleanup][14.1B.2E-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:10 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:11 3(0) Wed 01/26/2011 05:06:11 PM : [ Time] 17:06:12 3(0) Wed 01/26/2011 05:14:15 PM : MOD-EM-BRULTECH: Connecting to http://192.168.1.106:8083 Wed 01/26/2011 05:14:20 PM : MOD-EM-BRULTECH: Read Acknowledge Failed Wed 01/26/2011 05:16:11 PM : [ Time] 17:16:12 3(0) Wed 01/26/2011 05:23:20 PM : [iNST-SRX ] 02 50 13.ED.1A 00.00.01 CB 11 01 LTONRR (01) Wed 01/26/2011 05:23:20 PM : [standard-Group][13.ED.1A-->Group=1] Max Hops=3, Hops Left=2 Wed 01/26/2011 05:23:20 PM : [ 13 ED 1A 1] DON 1 Wed 01/26/2011 05:23:20 PM : [iNST-SRX ] 02 50 13.ED.1A 00.00.01 CB 11 01 LTONRR (01) Wed 01/26/2011 05:23:20 PM : [standard-Group][13.ED.1A-->Group=1] Max Hops=3, Hops Left=2 Wed 01/26/2011 05:23:20 PM : Duplicate: ignored Wed 01/26/2011 05:23:20 PM : [iNST-SRX ] 02 50 13.ED.1A 00.00.01 CB 11 01 LTONRR (01): Process Message: failed Wed 01/26/2011 05:23:20 PM : [standard-Group][13.ED.1A-->Group=1] Max Hops=3, Hops Left=2 Wed 01/26/2011 05:23:21 PM : [iNST-SRX ] 02 50 13.ED.1A 13.24.88 41 11 01 LTONRR (01) Wed 01/26/2011 05:23:21 PM : [standard-Cleanup][13.ED.1A-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:23:21 PM : [ 13 ED 1A 1] ST 255 Wed 01/26/2011 05:23:21 PM : [iNST-ACK ] 02 62 00.00.23 CF 11 00 06 LTONRR (00) Wed 01/26/2011 05:23:21 PM : [ F CF 73 1] ST 255 Wed 01/26/2011 05:23:21 PM : [ 17 F6 90 1] ST 255 Wed 01/26/2011 05:23:22 PM : [iNST-ACK ] 02 62 00.00.23 CF 11 00 06 LTONRR (00) Wed 01/26/2011 05:23:22 PM : [ Time] 17:23:23 3(0) Wed 01/26/2011 05:23:23 PM : [iNST-ACK ] 02 62 14.1B.2E 0F 46 00 06 IOOFF (00)
January 26, 201115 yr There is nothing from 14.1B.2E that looks abnormal at the beginning of the trace. At 05:23:20 PM a sequence from 13.ED.1A starts. This looks like a motion sensor motion On. What is 13.ED.1A ? At Wed 01/26/2011 05:23:21 PM : [iNST-ACK ] 02 62 00.00.23 CF 11 00 06 LTONRR (00) Scene 0x23 decimal 35 is turned On. At Wed 01/26/2011 05:23:22 PM : [iNST-ACK ] 02 62 00.00.23 CF 11 00 06 LTONRR (00) Scene 0x23 decimal 35 is turned On again. What is this Scene doing? At Wed 01/26/2011 05:23:23 PM : [iNST-ACK ] 02 62 14.1B.2E 0F 46 00 06 IOOFF (00) a command is issued to 14.1B.2E you indicate is a motion sensor. The command code is 0x46 which is an unusual command in and of itself and the motion sensor cannot react because the motion sensor is sleeping.
January 26, 201115 yr 13.ed.1a is laundry room ms i think the scene is outside lighting at sunset which is close to that time last run time is 5:35 and everything else in last run time is a least 1/2 or more before or after that time period. the motion sensor 14.1b.2e is outside and is also set to send dusk/ dawn commands. the program is set for either the motion sensor or sunset time to trigger which ever comes first.
January 27, 201115 yr What is the Program doing when triggered by 13.ed.1a? What are the Scenes doing if invoked from the above Program? Michel, There is a 0x46 command sent to a motion sensor. My OLD command document lists that as an I/O command and the Event Viewer trace tags the command as IOOFF Wed 01/26/2011 05:23:23 PM : [iNST-ACK ] 02 62 14.1B.2E 0F 46 00 06 IOOFF (00) Why would that command be sent to a motion sensor? Lee
January 27, 201115 yr the program is turning on 2 lights in a scene then waiting 7 mins and turning off unless theres motion withing the 7 mins.
January 27, 201115 yr FYI - I also get random screen pop ups stating "unable to communicate" with motion sensors on 2.8.10. They go away and I haven't paid much attention to them. I didn't think in regular use the ISY should be trying to communicate with a motion, just receiving.
January 27, 201115 yr Author Hi LeeG, Excellent observation. I have no clue where that is coming from but will get to the bottom of it! Thanks so very much. With kind regards, Michel
January 27, 201115 yr All, I think this motion sensor issue it what's been plaguing my setup. I disabled all of my Motion Sensors since version 2.8.x, because the PLM or ISY would eventually lockup. Since I've removed them, the system seems to be much more stable. I hope the team finds a solution, it would be great to re-enable my MS's Thanks for the support.
January 27, 201115 yr Author Hello ficklma1, Thanks for the update. Still trying to figure out where the message is coming from to no avail. Would you please go to your programs and do a Find for all your motion sensors? Please let me know if you have any motion sensors in the Action section of any of your programs. With kind regards, Michel
January 27, 201115 yr For those who cannot upgrade: please NOTE that you will have to use http://www.universal-devices.com/99i/2.8.10/ or http://www.universal-devices.com/99i/2.8.10/admin.jnlp (or 2.8.11). You CAN NOT use your current version coming from ISY. For future versions, this should not be a problem. Polexian, no, this is not a bug. We did verify that we are sending the correct message/command. The LED brightness works ONLY on SWLs with BEEP. It does not work on others. With kind regards, Michel What if you don't have internet access where you are using the ISY?
January 28, 201115 yr The steps you listed are different from the steps UDI published at the beginning of this topic for installing 2.8.11. Have you tried doing an install following the steps UDI published? i don't recall it being that complicated before. I guess i missed a number or steps.
January 28, 201115 yr Author Hello GregE, It's going to be problematic if you do not have Internet Access. With kind regards, Michel
January 28, 201115 yr The steps you listed are different from the steps UDI published at the beginning of this topic for installing 2.8.11. Have you tried doing an install following the steps UDI published? i don't recall it being that complicated before. I guess i missed a number or steps. Please notice this is a Beta release. The AutoUpdate for the next official release should work as usual (or we will fire the programmers!) Rand
January 28, 201115 yr The upgrade did not complete for me. I followed the exact instructions at the beginning of this thread but part way through the update process I get a pop that says ........... "Upgrade Failed:Failed uploading file (reported written size is invalid)" I have tried the update sequence three times with the same results. What's Next?[/img]
January 30, 201115 yr 1. I notice (after upgrading to 2.8.11) when the email (email user id) account settings is incorrect and I add a "notice" to a program; it fails the whole program. e.g. nothing work for that program. 2. I notice also that the whole server is unstable after that. e.g. does not response to turn on or off properly and display wrong info for the on/off status for individual switches A reboot fixed this after I entries a proper email user id.
January 30, 201115 yr Author Hello Gali(B"H), Please install our latest release so that we would have the same point of reference: http://forum.universal-devices.com/viewtopic.php?t=5867 With kind regards, Michel
February 6, 201114 yr Still not working. Actually even if the email info is correct it is still unstable and program don't work properly. Statuses are incorrect, devices don't respond all the time, and scheduled programs execute. I took out the email settings for now. We'll see how it goes. Gali
