Release 2.8.12 Is Now Available
Hello all,
Thanks so very much for all your help in this beta cycle. If no serious bugs are found, 2.8.12 shall become our official release.
We added support for PRO series and thus the continuation of Beta.
Please do be kind enough to :
1. Load Controller
2. Motion Sensor random IO commands
3. DSCLinc and program execution
For a list of changes, please take a look at this post:
viewtopic.php?p=6475#6475
Notes:
1. ISY-26 is no longer included in the firmware builds
2. Due to the sensitive nature of supporting MorningLinc, users now must agree to terms and conditions upon Admin Console start up otherwise the dialog keeps popping up every time the Admin Console is started
Instructions:
1. Please backup your ISY (File | Backup ISY)
2. Please download the firmware for your platform - please do not unzip
ISY 99i Series: http://www.universal-devices.com/update ... 2.8.12.zip
OR 992i Series: http://www.universal-devices.com/update ... 2.8.12.zip
OR 994i Series: http://www.universal-devices.com/update ... 2.8.12.zip
3. Important
Due to invalid Java certificate chain in releases 2.8.5 and above, please make sure to remove all Universal Devices certificates from Java:
a. Close all browser sessions
b. Open Java Control Panel (Java Preferences on MAC)
c. Click on the Security tab. Remove all Universal Devices certificates (on MAC, click on the '-' button at the bottom)
e. Clear your Java Cache ( http://www.universal-devices.com/mwiki/ ... Java_Cache
f. Go to http://www.universal-devices.com/99i/2.8.12/admin.jnlp
4. Login to the Admin Console and choose Help | Manually Upgrade [the name of your system]
5. Choose the file saved in step 2
MAC users: if upgrade fails, please add https://your.isy.ip.address to ISY Finder (see 3f above)
6. After the upgrade, ISY reboots. Please do ensure to clear your Java Cache:
7. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console:
a. http://isy/admin - applet (Windows only)
b. http://isy/admin.jnlp - Java application (Windows only)
c. http://your.isy.ip.address/admin - applet
d. http://your.isy.ip.address/admin.jnlp - Java application
e. http://www.universal-devices.com/99i/2.8.12 - applet
f. http://www.universal-devices.com/99i/2.8.12/admin.jnlp - Java application
8. IMPORTANT If you have already installed a self signed certificate and your current firmware is 2.7.10 and below, you must reinstall a new one:
http://www.universal-devices.com/mwiki/ ... rtificates
Thanks and with kind regards,
