Version 2.3 Is Now Available
Hello all,
Although we had promised to include enhanced trigger functionality in release 2.3, however due to the implementation of an overwhelming number of features and enhancements, we decided to release 2.3 without the triggers/scheduling.
Please note that your userid/password/location settings/email settings may be reset after this upgrade (admin/admin). Please do make sure to check your Configurations by clicking on the Configurations icon after the upgrade is complete. Sincere apologies for the inconvenience
As usual, please make sure you have a current backup of your configuration before upgrading to a new release.
Here are the highlights of version 2.3:
Bug Fixes:
XML Parse Error with certain firewall software
Fixed Lat/Long for Alberta, Canada
ISY hang after DHCP renew
Using a dynamic-DNS address would not get resolved when accessing ISY remotely
Extra html tags on the AutoUpdate dialog
Functional Enhancements:
Multi selection of devices to be moved into a scene
Support for KPL Toggle Mode
Support for KPL Synchronized Buttons
Support for one or more buttons from the same KPL as responders in the same scene
Support for Linksys Routers WRT54GS and DLink DIR-655
Performance improvements in system startup
Performance improvements in adding devices
Cosmetic Enhancements:
Changed the color to RED for a controller within a scene; everything else is blue
Left Nav bar widened to support long names
Changed the "Cancel" label to "Done" in certain dialogs
Added UDI Forum menu option to the Help menu
Progress bar:
- No longer Always on Top
- More accurate when clearing configuration before a Restore ISY
- More accurate after linking/adding/removing devices and scenes
If you have AutoUpdate credentials, simply logon to ISY and wait for the notification of the update.
Otherwise, you may download version 2.3 here.
Please don't hesitate to contact us with your questions/issues/suggestions.
Thanks for speedy update!
Tried out the toggle button feature -- any tips on how to trigger on a toggle button? I setup a trigger that says "when C is ON" which worked, then changed button to a toggle style. Now C just flashes twice and nothing happens... also tried "when C is OFF"...
-John
John,
Our pleasure.
Unfortunately, triggers (in the current incarnation) do not work with non-toggle buttons since they are "trigger" based and non-toggle buttons never change their state= they are always off!
I hope you can bear with us a little more till we get our enhanced trigger/scheduling functionality out.
-John
FYI: I noticed that my timers where not working after the update; I found out that it was because the custom lat/long did not stay set after the 2.3 upgrade. When you update the custom lat/long it starts working again.
Mark,
Yes. Thanks so very much for the information.
It turns out that 2.3 resets the main configuration which includes:
userid/pwd
Latitude/Logitude/TMZ Offset
email settings
I am so very sorry for the inconvenience.
With regards,
  • 4 weeks later...
